2001 isn't new lol, it's 24 years old, some 24 year olds are single mothers with kids from 2 different blokes.
Ok, so I've unplugged the transfer case first Fuse 32 to disengage the clutch 100%, then I did a test drive - nothing changed, so I pulled up to a car park, pulled the other fuse 63 out and once again nothing changed apart from a Christmas tree on the dash...
The first diagnostic on the car my dad received was that it's the rear diff, I'm starting to think that might actually be it... Thinking logically, at the front there's already an aluminium Guibo, at the rear there was a Rubber soft Guibo which was replaced with a brand new fresh firm Guibo which would amplify the vibrations. Is my thinking right?
I said newer! Meaning newer than my junk!
Audi found a way to make things really bass ackwards and awkward to work on way before their time. Even changing the battery is a pain in the arse involving removing the wipers and the scuttle panel and some covers and rubber seals, and then theres no room to get to the bracket bolts, and if you drop one its going into a void underneath the AC lines and will take you 20 minutes to extract it... The front suspension setup has 300 arms and ball joints, the entire front of the car has to come off to do things like water pumps and whatnot, hate it.
Its lovely to drive though. Doesn't handle worth a damn but its comfy and smooth.
