So I ordered one of these for £15 when it was on sale and it came yesterday.
I will start with the bad.
The rumble is terrible, it has off, medium or full. At medium it feels like a diesel engine, and at full it feels like a slightly worse diesel engine. No finesse and actually distracting. I turned it off after playing with it on in 1 race.
The sticks feels light, not as much resistance vs the more expensive pads, (PS5, Pro Controller 1 and 2, Xbox, 8BitDo, Cylone 2). The shoulder buttons are not the most comfortable due to the size of the controller but it certainly is much better than the joycon. The pad is light (neither good or bad).
It does not wake up the Switch 2 unfortunately. Apparently it can wake up the Switch 1.
The good.
It only cost me £14.99.
The sticks despite them feeling loose, they are actually Hall Effects. It comes with these thumb grips to add on them to raise them a little higher.
The D-pad is surprisingly good, it can be adjusted to just a 4 way D-pad or changed to 8 way with diagonals. It feels about 90% of the way to the Nintendo Pro 2 controller.
It's very small and great for travel. Or simply kept as the 4th controller.
I found the PDF manual in the 1st link below, for
L1031, L1032 which shows all that i said above.
查看仪表盘,分析数据
u5tqxzj1yb.jiandaoyun.com
