Blimey, I thought all India 787s at least were grounded until report of the trajedy in this thread!
Money!
I don't read too much into that, with the time they had they would have still been in 'WTF!' mode when they hit the ground IMO...I need a set of epaulettes. Then I can convincingly speculate the **** out of this.
One question I have. Something that really leapt out at me is the way the pilots said "no thrust". They didn't say "engine failure". Would that be expected?
Yep exactly. Barely 100ft off the ground and feeling yourself sinking. I wouldn't be thinking straight either.I don't read too much into that, with the time they had they would have still been in 'WTF!' mode when they hit the ground IMO...
Also the mayday call hasn't been "confirmed" yet so it could still be a false report as opposed to the video footage we've seen, for example.
That was reasonably irrelevant. In the 787 they're combined boxes that each contain a CVR and FDR, not like old times were you needed both to piece everything together. As soon as they had the first (which they did a day or two after) they had all the data.They have both boxes now so it's a matter of time.
No I think you're rightWell, just because they are designed with survivability in mind doesn't mean that they will not be damaged, either wholly or partially. There's a reason there are two.
Never mind, I think I'm wrong about that.
I visited the AAIB with work a while ago and got to talk to one of their team who works on recovering FDR data. They've had cases where the recorder was so damaged that the chips had to be manually removed and forensically analysed bit-by-bit to reconstruct the data. I didn't have a clue about half of what he was talking about, but it was fascinating nevertheless.Well, just because they are designed with survivability in mind doesn't mean that they will not be damaged, either wholly or partially. There's a reason there are two.
I'm right at the beginning of the process, making electronics for aircraft. I try to go to as many shows as possible always interesting.That's lucky, from my perspective as a pilot I don't think we get much opportunity to find out how all the other areas that make up the aviation industry work, which is a real shame. As for the AAI side of things, I find it fascinating as well and I must admit, it's something I'm thinking about pivoting my career into.
I did an Aircraft Accident Investigation and Incident Response course back in 2014. The investigation element was run by the head accident investigator of Scandinavian Airlines, also ex. chief investigator for the Norwegian Air Force. The incident response element was ran by the head of incident response for the Star Alliance carriers who was also a captain at bmi, ex Midland. It was one of the highlights of my career and was absolutely fascinating. I considered heading down that direction but the demand was mainly for those with an engineering background and not so much for those with an operational background. There are jobs out there but it's often a case of dead mans shoes. Consider joining ISASI to make the right contacts - https://www.isasi.org/That's lucky, from my perspective as a pilot I don't think we get much opportunity to find out how all the other areas that make up the aviation industry work, which is a real shame. As for the AAI side of things, I find it fascinating as well and I must admit, it's something I'm thinking about pivoting my career into.
I haven't seen mention of it in here yet, but a second Air India 787 Dreamliner has had technical issues today:
Air India Boeing 787-8 Dreamliner flight forced to turn back with 'technical issue' | LBC
An Air India Boeing 787-8 Dreamliner heading for Delhi has been forced to turn back after the pilot said the aircraft was facing technical issues.www.lbc.co.uk
Seems another one "today/yesterday" too but British Airways. A British Airways flight from London to India had to turn around mid-air when it suffered a 'flap failure' ...
British Airways flight from London to India turns round MID-AIR
The Boeing 787-8 Dreamliner was yesterday less than an hour into its journey from Heathrow to Chennai when a pilot suspected a 'technical issue'.www.dailymail.co.uk
Had to dump fuel before coming back to land, landed safely thankfully.
Yes looked like correctly setup for landing there.Not sure if ‘fail’ is quite the right word rather than just caution/warning message. Always best to get to the place you can most easily get engineering support if you can too.
You can see it landing here 7:54:30 with full flaps:
There’s also this story of the BA A380 getting 3 hours into its flight before turning back to Heathrow because that’s the best place for it:
