Temps rocket when "shaders" loading?
28 Jan 2011
Hey guys, I have had a few issue regarding temps while the game shaders are loading in..
My idle and gaming temps are very acceptable, but for those couple of minutes when shaders are being implemented, my fans go crazy and the temps hit 83-85c during this time.
Is this normal and OK to leave as it is?? I dialled in my fans in the BIOS to be quiet but ramp right up under higher load.
Shaders will hammer all the cores available whilst being built so it's to be expected that temps will ramp up.
thanks Glanza, one quick question mate, I just done an undervolt on my CPU via BIOS..
when I went to save changes and exit, it says nothing changed??? so i exited anyways, let it boot into Windows, restarted and went into BIOS and the UV was still enabled??
is this normal for that sort of tweaking???
is it an MSI board as it does the same for my Tomahawk?
This is normal. My 5800X3D often hits 90C during this process (although mine is particularly power hungry, I lost the silicon lottery).
Very normal on my 7800X3D CPU for shaders to rocket temps, I've my thermal temps set to 83c max in BIOS for CPU, I know the CPU can handle 89c according to AMD but I like to be on the safe side and not worry about it :) .
Remember there are some great settings in BIOS if things get too hot for your liking.
