What does this even mean, it's literaly gibberishfor ev rear legroom perhaps have to accept suv, vs saloon, height ..... 11/22kw charging, as well as nacs ?
Also what does NA stand for in NACS... do you think it's going to appear on UK cars
starmer should be visiting nissan plant too - looks attractive with z-car rear
Two and a half, been working from home a bit more than I usually would but I should still comfortably only need to charge every 2-3 weeks.Haven't you had it 3 weeks now?
I guess the 11kW vs 22kW thing is probably down to the simple fact 11kW is cheaper and easier to provide, people aren't typically expecting to fast charge from such chargers (if they want that, then 50kW+ DC is usually available anyway) so why bother with the added expense on either side of the equation for a relatively niche use case?
It only unravels a little when you get the combo of an 11kW charger and a car without 11kW capability - judging by the available filters on EV Database, the vast majority of EV models do actually seem to be 11kW (or better) compatible, accounting for 893 models of the 978 they have on their list.
I mentioned '11kW or better' because I included the 16.5kW and 22kW capable cars too in the number I quoted, as they'll also be 11kW compatible.It's showing me 590, and of those how many have it as standard vs an option the buyer needs to select?
On a work trip in the US at the moment.What was the situation? I thought they weren’t UK road legal?
Thanks, I'm going to charge over the 3 pin but with the car connected and charging the smart meter is supposed to be able to detect it, is that right?
Also, does anyone know if the large block that is on the 3 pin adaptor cable is waterproof?
I'm not using the official BMW 3 pin charger, but if i use the Ring Automotive one i have it doesn't detect my car, however the Ohme charger detects it and the Octopus app also now detects the car when plugged into the wall charger (i5) whereas before i did it all through the charger. I've ended up just staying with the charger controlling the overnight charging anyway, rather than direct connect to the car, just didn't want the trial/error of using the direct to car option.Thanks, I'm going to charge over the 3 pin but with the car connected and charging the smart meter is supposed to be able to detect it, is that right?
Does anyone have any real world experience of the ID Buzz? If so, thoughts?
Yeah plan to look at the label on it after doing some goggling about it. It may well state a rating..I'm not using the official BMW 3 pin charger, but if i use the Ring Automotive one i have it doesn't detect my car, however the Ohme charger detects it and the Octopus app also now detects the car when plugged into the wall charger (i5) whereas before i did it all through the charger. I've ended up just staying with the charger controlling the overnight charging anyway, rather than direct connect to the car, just didn't want the trial/error of using the direct to car option.
The large block on my 3 pin charger isn't waterproof. I'd suggest looking at the specs of your specific charger to see if it has an IP67/68 rating.
Ace things, also the LWB extra impressive for space and simple versitility in my view.
Well, it looks hilarious.
So approved used ID Buzz are dropping below £40k, the missus is considering chopping in the Discovery 5 for something a bit more economical now we don't have any farming duties to worry about (we've got some real big bills coming up for it so looking at all options). Basically she asked me to look at something EV that has a similar footprint or a little smaller compared to the Disco to see what the options are. She quite likes the look of the Buzz (as do I strangely). But I've never driven one nor been in one yet.
