- 14 Jun 2004
wifi 5 AX router can also work well. its a personal preference and depends on specs. having a dedicated router is prefered depending on distance and network traffic.
Hmm ok. Seems like I also need to download the streamer app on the PC. Might give it whirl later. ta.Virtual desktop these days need a puchase on the headset your using if its a standalone headset.
if your a wred headset then my understanding is the PC verision of Virtual Desktop is legacy and for rift series? - never really looked in to that side of it.
in short buy the quest version
you also need a dedicated wifi 6e router wired to your pc. check out the youtube videos.
Just to correct this, wifi 5 is perfectly fine
I upgrade to 6E and I saw no difference in performance
Bit of a thicko question but can I use this via VD, which I purchased donkies ago for the Vive? Or do I also need to also buy the Quest VD version? Confused how VD versions differ considering it all relates to PCVR gaming.
Haven't played it in VR for a while now, but learning always run through VD for all my pc VR games and it worked fineIs anyone here playing Elite Dangerous on Virtual Desktop? I have tried suggestions on the frontier forum, used a switcher to ensure Openxr is running but no joy. Got it working with DCS and Il-2 Great battles
I'm tempted to reintall Elite just to see what its like in VR
If you start Elite Dangerous from the Games menu inside Virtual desktop does it not start in VR mode automatically? I know it used to, it was how I always played the game.Thanks I will try that.
