HAVN HS 420 and HS 420 VGPU Case
A few people have said this case is the best case of 2024, which is quite a statement considering we're near the end of the year now. :)
There are certainly more products in the pipeline, there's currently 3 USB ports on the top of the case (2x USB-A and 1 USB-C), how many were you thinking? :)
Yes and no, the HAVN brand is part of Pro Gamers Group, which is the same company that Overclockers UK is a part of. But Overclockers UK themselves are not the team putting this case together, it's a separate team. However, Overclockers UK have had some input in the development stage as a system builder.
Correct. :)
It's a very unique design, this case certainly has a lot of features which sets it apart to other "fishtank" cases, not just the bottom fan, but the cable routing system behind the motherboard tray, the cable grommets, the panoramic glass, the air guide glass, and the entire structure of the case is unique in terms of the ventilation and cooling, HAVN developed the case from the ground up and is not a clone or a copy of any existing case on the market.
Glad to see the leaflets being noticed. :)
You're going to be very pleased with it! :)
just waiting for the core ultra 285k to arrive! any ideas when they will finally be landing in the UK?
Yes the leaflet came with my new motherboard, so went to check it out.
Very pretty, wish I had a use case for it. I run 2 360mm radiators and this seems very good if I want to show it off with RGB fans, but right now satisfied with my no window build.
Just only built my mini ITX Terra build, I cannot justify another build.
@fiveub Case looks great. Do you know if the VGPU kit will be able to be purchased separately if you'd wish to in the future to add to the base model or are the constructions entirely different? Cheers
We plan to release a VGPU kit separately, hopefully in the coming month. :)
@fiveub Any change of the discount code being reenabled to get the vertical case for same price as the horizontal? Went to order earlier and looks like it's been taken off :(
Hey,
Unfortunately the discount code for that promotion has now expired, and we’re unable to re-enable it. We understand how disappointing it can be to miss out, but we’re confident you’ll find the case is worth every bit. :)
Does the normal case support angled fans too? I like the aesthetic of the angled fans but don't wanna vertical mount my gpu
Took longer than we hoped, but the accessories for the HAVN HS 420 are now available here: https://www.overclockers.co.uk/cases-and-modding/case-accessories?manufacturer[0]=HAVN
Also, JayzTwoCents published a video recently on the HS 420, the case is being well received and considered as the best on the market.
Watched that review and he made it sound like there was limited clearance in the top for radiators. Do you know if it would fit an Arctic Freezer III 420 in the roof with it's 38mm thick radiator (+ 25mm fans)?
@fiveub I've just rebuilt my system in the 420s and it's certainly my new favourite case to build in. There's only a couple of things I'd like to suggest, most importantly is we need a full peel on that glass. It's the most satisfying part of a new build!
I think some guides at the bottom of the glass would be helpful, as I noticed a tendency for the glass panel to swing in at the bottom. A little more space for stuffing PSU cables would also be nice. Oh and maybe a dual argb fan hub.
I genuinely enjoyed building in it though, I can't wait to see what you guys come up with next.
Haha, maybe we should supply extra sheets of glass with film on for people to peel! :D
Appreciate the feedback, I shall pass this to the team, and I'm glad that you enjoyed building in the case. The quality and design is the best I've ever seen in a computer case! - They have some great products coming out this year which will expand on their portfolio. :)
Honestly, a lack of satisfying peel cannot be understated!
I'm genuinely looking forward to seeing what comes next from you guys, I'm certainly going to be recommending the 420s to anyone, who's budget allows for it, and can't see me wanting to change cases any time soon.
I've currently got a simple air cooled build in at the moment, as I wanted an easy life away from water cooling but knowing me, and with this case begging for it. I'll probably oblige! Haha
I see the various Havn case accessories are available to buy separately now. In the standard HS 420 with a GPU mounted horizontally, would there be any benefit or disadvantages to replacing the bottom flat mounted fan backet with the angled one. I just think it's aesthetically nicer. I assume the glass partition that attaches to angked bracket would be pointlews if the GPU is mounted horizontally though
