Try looking at the windows reliability monitor:
Windows Reliability Monitor:
Control Panel\All Control Panel Items\Security and Maintenance\Reliability Monitor
(this site has more details:
https://www.dell.com/support/kbdoc/en-uk/000178177/how-to-use-windows-reliability-monitor-to-identify-software-issues#:~:text=Windows%20Reliability%20Monitor%20is%20located,(See%20Figure%201.)&text=You%20can%20also%20access%20the,search%20box%20from%20Start%20Menu.
Also, try:
Local Disk (C: > Users > My Username > AppData > Local > Activision > Call Of Duty > crash_reports
Inside the ‘crash_reports’ folder, you will see some compressed files.
Sort everything by date and open the latest one using 7-zip or what have you.
Inside the file, you will see a text file called
dxdiag_oncrash.txt.
Open it, and scroll down all the way to the “
Diagnostics” section, inside the text file only.
In the Diagnostics section, there will be “
Problem Signature”.
In Problem Signature, you will be able to see which process or service caused the crash
