- 24 Jun 2021
- Oxon
A bunch of stuff to consider:
When did you build this pc / how long was it fine for?
Have you made any recent changes, hardware or software?
What are your CPU temps?
Is your aio pump pumping?
What ram do you have? Can you test it? Memtest / try individual sticks?
What storage do you have? Can you check crystaldiskinfo/crystaldiskmark?
Can you rule out the GPU by using the CPUs graphics?
Do you have the latest bios installed?
