installed latest studio driver, booted up stellar blade and the frametime graph is ******** the bed, back to 566.36
Must be pedcak, as I hear studio is rock solid. Studio is life!
May be of use to some, I checked and in the Nvidia profile inspector and it was disabled for me, Re-size bar not enabled fully?
This is by design nvidia use a white list for resize bar, thats why its not on globaly.
Ah, that makes sense about the individual profiles, I checked and you are correct. I changed to enabled but guess it probably will just change as required anyway.
Thanks, it did take me a bit a while ago to work out why it would not enable, not the video change above, that I had to disable the CSM setting in the bios, I don't recall enabling that so possibly somehow reset it back on, but now workingYou need to enable it globally in the bios. But then Nvidia will choose to use rebar on a per game bases.
Have you removed the drivers with DDU and reinstalled ? i.e a clean installBit of a longshot question, but has anyone ever known a certain set of NVidia drivers to cause issues with mouse lag and stutter?
Since updating to the latest drivers (which seem really good for my 5080 and have solved a few issues I was having) I keep getting random bouts of extreme mouse stutter and lag - on the desktop.
Never had this before, ever, in 25 years of PC use. Can't see any reason for it, CPU usage and everything at minimal normal levels. Only thing that has really changed on my system in the last week or so, is installing the new Nvidia drivers. I'm stumped.....
566.36I'm currently on 560.94 after a new Win11 install, what's the next one up from that for rock solid stability (if there is such a thing with drivers) ?
Yep, I have this and it lags badly when I open up Steam (for example). I've had it a long time, certainly pre-50 series.Bit of a longshot question, but has anyone ever known a certain set of NVidia drivers to cause issues with mouse lag and stutter?
Under the "Advanced display" settings for your monitor in the Windows Settings app, look where you would adjust refresh rate and see if "Dynamic refresh rate" is switched on. I had this issue with my 3080 until I switched this off, and it has no affect on VRR for gaming.
Edit: https://imgur.com/a/hPtP9do
As long as he's running an updated version of Windows 11 it's there otherwise else should they be using? Windows 10 is dead shortlyNot all GPU/Systems have this option btw. Just incase he can't find it
