How weird. Yes I saw the article mentioning performance improvements on the wccf website and downloaded AGESA 1.2.0.3e dated 10th June from thereWhy does WCCF have Google drive download links to a version ASUS doesn’t have on their site?![]()
Version 3265
15.61 MB 2025/06/23
SHA-256 :14810002E37A9CDA4CFC72DF5086D20C7981093354856EC7F05A9F90F21475E7
"1. Updated AGESA to ComboAM5 PI 1.2.0.3e for upcoming CPU compatibility.
2. Enhanced system performance and stability.
3. Important: This update is irreversible. Rolling back to older BIOS versions is not supported.
Before running the USB BIOS Flashback tool, please rename the BIOS file (SB650EE.CAP) using BIOSRenamer"
Installed and working so far, took a long time to update (10-15mins).Don't think this was posted, new official BIOS out.
I had to download it from Global site, running fine on my board.
Download Link
I have a gen 4 WD SN850X in the top slot and a gen 3 Corsair in the next one down and my 6900XT gets full 16x.Can anyone help me with my issue, I have 2 x nvme drives in this board, a Samsung 980(gen4) in the top slot & a WD blue(gen3),in the next. Nothing in the bottom 2 slots. I upgraded to a 5080 a couple of months ago can only get it to run @ pci-e 5 x 8. I've swapped the WD blue about in all the bottom 3 slots,but no luck . From what I can see in the manual as long as I don't use slot 3 my gfx card should run @x16. Can't seem to get it to work
Any help would be appreciated
Rob
Don't know what I can do to resolve my issue, thanks for the replyI have a gen 4 WD SN850X in the top slot and a gen 3 Corsair in the next one down and my 6900XT gets full 16x.
Rob
Thanks for the reply,I've got it set to x16 in the bios, I'll swap them about & see what happens. I know it's not a big difference in performance,but it's just doing my head in. I even updated to the latest bios today just in case.no luck either. As I stated earlier,my 3080 was running @x16 with both drives in the same slots,it's only since I put the 5080 in. So looks like a pci-e 5.0 issueYou can go into the BIOS and force the GFX card slot to X16, then if a drive disappears you know which one is causing the problem. Theoretically, as you say, it should only be a problem in slot 3 (bottom left), but you never know if something has changed in newer BIOS's. It also might be an idea to try both drives in the two right most slots, as they are the pci-e 4.0 slots and you are leaving both the pci-e 5.0 slots unoccupied.
Failing that, although it may be annoying, it's not such a bad thing to leave it at x8 as you lose on average 1% performance or less.
Had a really weird issue with my Strix B650 based PC.
My PC wouldn't boot. It would turn on but got stuck at a yellow light on the MB, which apparently is a RAM issue.
I tried leaving it for a good few minutes and eventually it booted into the bios screen but it was completely corrupt. Covered in speckles and noise, and completely messed up. It was still possible to navigate but you couldn't read it.
It looked like a borked graphic card, or some issue with RAM or the CPU which I was dreading trying to diagnose as I don't have spare RAM or a CPU I could swap.
Luckily it turned out just to be corrupted CMOS memory, and a resetting the CMOS fixed the issue.
I've never seen a corrupted CMOS do that to a PC before. I've seen them not boot or error on boot, but to boot into a completely corrupted BIOS UI after sitting ten minutes without any activity is really weird.
