£50 or so is not bad in my view.
Presume this comes with better quality than it did in the mid 90s?
Yea 50 buys you a new front board with an IPS screen attached simple plug and play and off you go.
Vince, I've got a sticky RB because I got a small bit of squash on my Switch 2 pro controller lol.
Watched a teardown video, looks simple enough but the front cover is glued on and I'm not sure what kind of glue I'd need to get it back on (if any) or should I just heat the old glue up again before I replace the cover.
Cover removed at 9:20
Only one way to find out I bet it's just a bit of 3m if it isnt a bit of B7000 will 100% get it back together and looking normal. Chances are though you can probably just slap it back together and it will be just fine
Why people buy the pro controller when the King Kong 2 pro exists is beyond me it's not as nice as the king Kong, has inferior parts and sensors all while being more expensive. Get the king Kong, scrap the pro controller
Not heard of it before but looks decent. However, I bet just like the Switch OG Pro Controller, it can't be used to wake a Switch 2.
Thanks for the glue advice, was such a freak accident and it just happened to hit my controller![]()
Never heard of them before but I'll keep an eye out to see if they do a S2 version and give it a go.Ahh that makes sense they are letting the pro 2 wake the console - Honestly though the king kong is easily the most accurate pads ive ever used, less than 0.5% out in circularity which is crazy stuff
Where can I get this from? Plus tools/instructions?Yea 50 buys you a new front board with an IPS screen attached simple plug and play and off you go.
Where can I get this from? Plus tools/instructions?![]()
My favourite all time handheld is the Nvidia Shield Portable, I've got two - one on the older firmware with all the exclusives still installed (Half Life 2 etc), and another i accidentally updated.
Do you get many cross your bench? How feasible would it be to update the charging port to USB-C? Maybe a battery upgrade?
Hell, maybe even a screen upgrade if such a thing is possible! I know it's a fairly niche console, so probably not something that's possible.
I'll do a full write up on it but it would be rude not to do a full recap, full power overhaul, the works. It's one of my grails and ive just not found one thats worthy (havent looked that hard because they are big bucks) but this one is beautiful.TBH I've never had drift, and I've never really worn out a controller other ways but have kept some for 10+ years. Still got my original PS2 pads!Not surprised by the "never had drift crowd". It's just fanboys for X company, that can do no wrong.
But that doesn't mean I'll argue with the data, plenty of people get drift routinely.
