- 23 Mar 2011
We are going on the market! But before i let them take photos I need to quickly sort this embarrassment out
Not a task I've done before. Bought some sand paper and a sanding block. Doesn't really seem to remove the paint? Just makes it smoother no matter which grit I tried.
Is it just a case of going over the door to make it smooth and soften the cracked paint a bit/blend it in the just slap some new paint on top? Same for the frame too. It's metal skinned.
Just want to tidy it up.
Which brand paint would you recommend?
