If they offered a daikin that wasn't so hideously ugly I'd probably go for it.Similar fir me. A price i am happy to pay, but trouble is i would need at least a 12kw heat pump and they won't do it. Yet.
Is it an old house, or particularly large? What is the footprint. We had one fitted to a 1950s bungalow which is 120sqm and the 5kw is more than enough. Installers still have a habit of oversizing so something to be cautious of.Similar fir me. A price i am happy to pay, but trouble is i would need at least a 12kw heat pump and they won't do it. Yet.
I would invite a reputable local installer to quote to be safe. 12kw on the face of it seems significantly oversized.126sqm, circa 1920's. Don't think you can do anything to force octopus to install really. They already did a survey![]()
Its a shame they don't offer the valiant stuff. The quotes on their site are now all for a cosy.
Not necessarily, a 1920’s property could be in the region of 65-85w/m2. At the upper end of that range would put the heat loss at >10kw to a 12kw Daikin heat pump would be about right as the next unit down in the range is 9kw which would be too small.I would invite a reputable local installer to quote to be safe. 12kw on the face of it seems significantly oversized.
You'll need a larger cable for the unitower as it has a 6kW immersion IIRC. Also the immersion doesn't work if there is a communication fault or the pumps not running in the heat pump. The immersion is not in the tank, it's in the primary circuit, so can be used to boost heating if required, sounds like a good idea, but the downside is you may not be able to heat the tank, we were without hot water for weeks due to an issue.I'm thinking of getting a Vaillant Arotherm Plus installed this winter. But this summer I'm doing a bit of home renovation and wonder if it's worth doing a bit of preparation.
I'm doing a full house rewire, so the floorboards are up. I wonder if I should run the electric cables for the outdoor unit (something like 6 sq mm cable) and the indoor unit uniTOWER (say 2.5mm or 4mm cable). Also wonder if I should put in two 28mm water pipes under the floors, for the connection between the outdoor and the indoor units.
This is to avoid getting flooring lifted again in a few months. What do you think?
I know it's neater, but I'd go for a normal heat pump tank if doing it again.
You can also go for a regular 3kw immersion of you get a regular tank.
Should solar export rates drop, you also have the option of sticking an Eddi on it and soaking up some solar export that way.
If the heat pump has a fault or the pump dies you can’t heat the cylinder using the immersion because it’s controlled by the heat pump.Interesting, what was the issue?
Do you mean that if one has a standalone water cylinder, he can have hot water for showers, even if the heat pump is not working?
That’s a hard no, I’d rather take the risk with my healthI've heard cold showers are healthy![]()
Assuming they have a slot for a regular immersion, yes.I didn't know such a device exists.
Would Eddi work with a Vaillant uniSTOR Heat Pump Cylinder or plain uniSTOR Cylinder?
This is what happened to us. A relay went on the motherboard and left us without hot water or heating, we have a split system so the heat exchanger unit is inside the house and a separate hot water cylinder with an immersion element. All I did was wire up the immersion element separately while the heatpump wasn't working.Interesting, what was the issue?
BTW I've heard cold showers are healthy![]()
