We've now moved to Frenchay Village. Geographically we are on the same side of Bristol but we've
technically moved to South Gloucestershire. We've moved from the Red to the Green.
It's weird. It's very much in a built up area but once you turn into the village it's like going back in time. Lots of manor houses and green spaces. It's like a cheat code living in the city!
If you look on the map once I cross the dual carriage way it's nothing but green and quite a nice ride to Chepstow and a few other bits. I haven't explored as much as I should've but looks like a lot of potential
Oh you're not in the city being there - I'd barely call Fishponds in the city, but more classic Bristol rather than the modern centre of the city isn't it. Lots of 'districts' with their own personality. Looks an ideal spot for what you want it for - a bit of a quieter place to live and school/family spaces etc (not that your old place was bad). While also some perfect quick links out into the country - along with the quick access to the motorways too! Should be lots of cycle paths there with UWE near?
Looks easy using Bristol road or Westerleigh to get out and avoid the motorways going under/over them to link out without using biggest A roads. Although the river to the East does limit some options there's a couple of bridges, looks like could even be a cycle path along your side of it that then goes under the A4174 and the M4? But could be footpath only as is labelled 'Frome Valley Walkway'. Looks like a cycle path alongside the A4174 easily accessible from Beckspool and Penn Drive. But that just follows the A road and doesn't look to give you an
easy way over it until Bromley Heath, but that would take you under the M4 too is probably going to be a regular thing. Or you reach the
A432 roundabout with looks miserable, but you have a cycle path north along it which takes you most of the way to Yate along there too. #stalker
I've used this calculator for years...
www.machinehead-software.co.uk
A 450mm chainstay with an oversized rear derailleur, combined with 42T chainring and 44T largest sprocket is rounded to 59 inches (118 links).
A 118 or 120 link chain is fairly common and should be easy to get with a 114 being the common 'short' one.
They seemed to use the tube from a presta valve but then unscrewed the valve top like you would to add sealant and then screw in the new click valve. Seemed a simple job to swap.
<snip>
Imagine most cyclists wouldn’t be switching though without a real push from the cycling industry.
Seems like a neat way of doing it - just new valve cores. Adaptors for pumps? Really the push has to be more than 'ease' for new riders to identify pump/valve type. As means instead of the 2 (common, there's others) easy to identify, adding a 3rd in. Yes easier to mount/unmount a pump. Are they more reliable so less pressure lost fiddling with the attachment. Are they wider and have better flow for putting sealant in. Are they less prone to failure from dirt/corrosion. Give us some benefits other than 'newbies find it easier'
anyone running elite wheels here? I ordered a set of elite ent gravel to upgrade from my heavy factory boardman wheels as I feel that's the one thing bike is lacking, just wonder if anyone else is running a set.
Nope, not really heard of them... Just more cheap chinese carbon?
All fair comments, I guess it's because it's easier to get two sets of wheels than have a road bike and a gravel bike. The motor is because I live in really hilly area and really can't be arsed to go out on my non e-bike most of the time!
We don't know you in here, so we don't know if you're a rider, what you want it for, what you already have, or are spending that lump of cash to 'get into cycling'. We have no context to base much advice - other than the usual slamming of someone getting an e-bike 'because its easier to go up hills'.
It's a lot of bike, but also a lot of money. Without context we're left trying to justify it to someone we might think is a newbie. Yes it'll be a good bike, a good gravel e-bike. Yes you can ride it on the road, but it'll be slower than an e-road bike. Likely heavier as made to be more stable/solid for gravel. It's entirely possible the gearing is quite low for Gravel so you'll end up with a bunch of gears unused on the road along with missing a lot of top end if you're looking to keep up with friends on road bikes (if that's a thing). So even for that money without the motor it is slower on the road than a cheaper road bike. Especially when missing much e-assist at the higher speeds, you might not even get anything from the motor for 99% of your riding, in which case it would be almost a complete waste of money. Context is key!
