There are multiple threads on reddit it about. Desk mounted? Wheel stand or some type of rig? I'm starting to wish I han't started with it allI've just ordered a Moza R5 bundle (i'll pickup a load cell mod for the brake at some point). Any gotchas or tips for getting it setup properly?
It will be desk mounted initially, but i also have a GT Omega Stand i'll end up using. I'll check out Reddit too (i try to avoid it usuallyThere are multiple threads on reddit it about. Desk mounted? Wheel stand or some type of rig? I'm starting to wish I han't started with it all
Same, from what I’ve learnt, knees need to be above your hips, back lent back slightly and your wrist should lean on top of the wheel when stretched out.It will be desk mounted initially, but i also have a GT Omega Stand i'll end up using. I'll check out Reddit too (i try to avoid it usually)
Get the formula wheel - the cheap Moza one that replaces the supplied wheel. I find it more comfortable, and it's slightly lighter so the FF is a bit more pronounced.I've just ordered a Moza R5 bundle (i'll pickup a load cell mod for the brake at some point). Any gotchas or tips for getting it setup properly?
Cheers, I'll look into that.Get the formula wheel - the cheap Moza one that replaces the supplied wheel. I find it more comfortable, and it's slightly lighter so the FF is a bit more pronounced.
Yep. That's the one. The supplied wheel has slightly rough textures where my thumbs rest, which is a tiny bit uncomfortable. The open wheel one is smoother.Edit: This the one you mean? https://www.overclockers.co.uk/moza-racing-moza-es-formula-wheel-rim-upgrade-rs032-gc-00r-mr.html
I picked up the Formula wheel from OCUK and it arrived today. Had a quick go of it and its really good for such a cheap mod.Yep. That's the one. The supplied wheel has slightly rough textures where my thumbs rest, which is a tiny bit uncomfortable. The open wheel one is smoother.
I bought my wheel direct from Moza, I think it was cheaper (but not much) They have UK distribution, so no import fees and they were quick too. But they seem to go out of stock everywhere, so if going to buy I'd just grab it where you can.
Yeah, mine has stayed on, as it's just as good for sports car stuff anyway.I picked up the Formula wheel from OCUK and it arrived today. Had a quick go of it and its really good for such a cheap mod.
What are your thoughts on it? Does the action feel good? Is it decently weighted, etc.?Moza user here and had no issues at all. Order from a uk supplier and you should be fine.
More than happy with it although only have a cheap Logitech to compare it to.
Seems responsive enough and definitely feels premium
