That's much better, yes you can have the points, even more if you put a cold bottle in there aswell![]()
Do I get a few more points now?
If you're after a portable unit, the main number one thing you need to look out for, is the exhaust hose kit itself. If it can not be put out of the window of your intended room for any reason (gap too small for it around the window, window opening is large enough but at a height too high for the exhaust, etc for example), then the portable unit is useless. You will need to basically hack a ad-hoc janky solution to it to convert it from a larger exhaust size to a smaller one that fits and try to seal it up to get it to work at that point, or have a large chunk of the flexible exhaust hanging outside the window (this might not be a problem for some locations, but can be for others).
Only after making sure that can happen, do you look for other details of the unit, like dba when in use (how loud it is), BTU it cools (typically determines room size it can handle), etc.
Thanks, long-term plan is to get a split system installed but have been advised we need the consumer unit changing before we can do this, so stuck with portable for now.
Plan temporarily is to cut a piece of perspex to fit the window opening , pipe insulation glued around the edge of this, and then use the squishyness (new word) of the foam to hold it in place, with the hose mounted to a hole in the perspex. Might even use ply to be fair, probably easier and cheaper. It's a bit of a janky solution but should work, have used similar in containers that have been converted for office use before.
Hose to window opening would be about 4ft, Could put it out of the top-opening window but thats more like 6ft and not sure they can "push" the air that high?
Loudness is a concern, but hoping that by running it for 1.5-2hrs a night should bring the temps down enough to sleep.
BTU wise, I think i'm looking at between 10-12k , I'm reading that having overhead is useful.
Anything else I should be looking out for?
Just be happy looking at all these moaning comments on the weatherIt's just miserable now with rain and cloud. Still feels warm but I miss the sun.
I just keep my doors and windows closed, it's cheaper18°C and heavy rain with distant thunder.
Fingers hovering over the heating on switch![]()
I velcro mine to to the window opening, used a bit of 6mm hardboard I had lying around.Thanks, long-term plan is to get a split system installed but have been advised we need the consumer unit changing before we can do this, so stuck with portable for now.
