That is ultimately the end goal of this thread, IMO. Drive away!Now to drive the ****ing thing a bit more!
Private, or you going via Motorway or CarWow? I kinda regret not trying the new auction feature on AT. I was hesitant, as it's new and was thinking not a lot of dealers know about it.Gave the wife's Evoque a good clean and took photos to hopefully get it sold.
At a glance, unless the tester knew that model of vehicle very well, I'd say they'd likely fail that, as they look like two rust holes.Did some de-rusting, re-seam sealing, and painting/rust converting on the area above where the subframe sits on the E30.
Those holes are supposed to be there, but they are meant to be a proper oval shape, not the shape they have ended up after descaling. Like so:
Deciding if I should do something about it or just leave it like that. Slightly concerned that MOT testers might not know there are meant to be holes there, and fail it on seatbelt anchorage prescribed area.
Easiest fix would be to find a couple suitable grommets. Ideally you'd want some blanking grommets, but I'd guess finding a couple oval ones a suitable size is likely to be a challenge, however a google search for "oval blanking grommet" does give quite a few results. Even if you need to cut and shut a couple for each hole, you can put a layer of seam sealer/underseal to make them blend in a bit.
@JonRGV250 like bean tins so I've heardI might just bond something over the top of it. A bit of aluminium perhaps...
Going to try Motorway/Carwow and see what sort of offers come from that.Private, or you going via Motorway or CarWow? I kinda regret not trying the new auction feature on AT. I was hesitant, as it's new and was thinking not a lot of dealers know about it.
I'd like to think that if a tester saw 2 pretty much identical holes that aren't corroded and crusty, then they'd assume they are meant to be there and wouldn't be concerned.Did some de-rusting, re-seam sealing, and painting/rust converting on the area above where the subframe sits on the E30.
I am however probably placing a little too much faith in common sense here.
Best weld a bean can over the area, just to be sure.
No idea. Either that or just a hangover from manufacturing.Are the holes not there for a reason? Drainage maybe?
