Not £100 good though! That's an extra 20% on top of MSRPIf you end up with the Trio, it isn't a big deal, the cooler on them is quite good (going by TPU's review), but I do understand the point that £100 is too much.
What specific model was the AMD card?Before I do, just checking it's 100% compatible with my system please?
No, you're right, my bad.I don't think I'm ordering the Ti?
It depends how cable managed your build is and how accessible the PSU's modular panel is.Okay thank you but that's no biggie right? Easy to get hold of?
Okay thank you but that's no biggie right? Easy to get hold of? If so, shall order https://www.overclockers.co.uk/sapp...6-pci-express-graphics-car-gra-spr-03983.html now.
There's a bunch of leads in with the motherboard box
H1-06
600W
CPU
H1-05 X2
H1-08
Maybe I game not followed the thread correctly, but did you mean to link the AMD card as I assumed you had now gone for an Nvidia one.?
Yes indeed and Tetras has confirmed it can be done![]()
So, did you end up going for a 5070 Nvidia GPU...?
When I last tried to use an AMD GPU it was fine with the AAA titles that I tried a tthe time, but was pretty bad with the Indie games I played. In the end, within two weeks, I had refunded it and gone to an Nvidia GPU.
Yes, arriving tomorrow, shall install it and then arrange for the AMD to be collected.
If there is one thing to learn from this thread, it's litsten to others with more knowledge than I ha. Would have saved me 2.5 weeks of pain.
Yes tempted by the Ti, but let's be honest, not really necessary for classic wow![]()
