Jack Pads - which ones ?
[ Oh - you know about bicycles do you ? I'll pick your brain next time
I spent 4 hours today transplanting a new frame into my daily - getting the pedals off of the crank was a plus-gas/torch .. I think the oven finally cracked it - affair ]
No the Chinese cars are made of cream cheese (it's a well known expression) pre-dating Wallace - pretty sure I'd have broken lesser quality/chinesium spanners than the real facoms I used today,
buy cheap buy twice
my older bmw had jack-pads incorporated , I guess the manufacturers used to have half an eye on the home DIYer, now cheaper construction techniques with pinch welds
make a better quality support necessary, for the throw-away car.
commercial garage obviously has robust swing arm type lift, versus diy with trolley+axle stand combo which need something sympathetic with the car chassis.
I dislike pinch weld jack points, it's a right pain in the rear. The savings they make for 50p worth of steel plate. I have a slotted jack but even that likes to crack the paint on the joint
Entirely depends on how its done, my old focus had pinch weld jacking points which were just a extra layer of sheet steel total crap jacks destroyed them my saxo has pinch weld jacking points as well but they threw in some 3mm plate, my jack had a pad on it but for jacks i fold up a offcut of carpet to sit on my axle stands.
good idea for axle stand solution - have some offcuts with strong hessian back also used for relatively heavy living room furniture.
The issue is mainly avoided with a trolley jack with wheels that can roll. Jack up anything on a trolley jack that sinks into tarmac and it will knacker the sills anyway.
I use these for my jack stands. Seems to work OK. £3-4 IIRC.
Got mine from Temu, it was under £3 and like an idiot I got 2 for my Sealey Trolley Jack because they were made of Chinesium. A year on and the first one is still perfect though so would recommend.
meet the new jack -
might have been nicer with stealth poly wheels, but the aluminium component/ reduced weight and more secure larger saddle compensate.
That’s not a jack pad ? Which one did you buy. How did u buy the jack with out research post
Great jack by the way. Mines great
meet the new jack -
Is that Motamec MT25ALBLK? Winntec has some nice quality alloy jacks with poly wheels. :)
you didn't think it would be that easy did you ?
hadn't thought that the pinch weld is so short that there isn't space to jack on it and put a stand there too.
(after I cut down a jack pad for the tripod)
