- 18 May 2010
- London
New bios posted
Re-seat your GPU in the socket, should fix it assuming you have a 16x card.Anyone facing Pcie stuck at 8X ?
Will need to test stability, but this has let me run 3:2 FCLK at 2067Mhz and UCLK at 3200mhz with Memory at 6200MhzAnother new bios released
7E59v2A81
Enhance memory overclocking capability.
Samsung 1.25V low power memory optimization for 256GB capacity.
They did, already been replaced with 7E51v1A65New bios for X870 tomahawk, new agesa version and security patches.
Flashed it, seems fine. We'll see if MSI pulls it (jinx)
Flashed it - let's see how long it takes this timeThey did, already been replaced with 7E51v1A65
Love a new BIOS update! I might be overdoing things like many people, but I always check and update as soon as there's something new to update. Provided there's no problems or faults posted around the internet.New x870e BIOS as well
Nope, zero problems here. Spec in sig.Anyone with a 5090 and an MSI x870 board?
I seem to recall people were saying they had long-term issues with the motherboard coming out of sleep mode/cold boot which I never experienced before
However, since installing an Nvidia 5090 FE on Saturday, the system does feel a bit sluggish when out of sleep. I wondered if it was related to PCIE 5.0 somehow?
Yes, but doesn't appear to be the issue you noted. I've had intermittent issues where there's no signal from the DisplayPort. Always fine over HDMI.Anyone with a 5090 and an MSI x870 board?
MSI 5090 Ventus 3X OC paired with MSI X870 Tomahawk WiFi & AMD 9800X3D, Corsair Vengeance 64 GB DDR5 6000 MT/s CL30, Corsair RM1000x PSU, MSI MAG 275CQRF-QD monitor, with the following symptoms:
Black screen on reboot or hot restart (not allowing caps to discharge in system).
"Blindly" typing my password in takes me to the home screen, where the graphics card seems to kick into life and display output.
Fine if I use the iGPU (if enabled) or an AMD RX 7600 graphics card.
What I've tried:
Happens regardless of if I use W11, Linux (Fedora), or even without any boot drive and trying to restart into BIOS, e.g. after changing settings.
Tried various BIOS versions on mobo (A40, A44, A51, A60, A61). Currently running the A61. Latest NVIDIA drivers in W11 and Fedora. Latest VBIOS (98.02.2E.40.AF) according to MSI Center.
Switching PCI-e GEN1/2/3/4/5 on the graphcis card slot.
Power cycling the monitor.
Using an alternative DisplayPort cable that is known to be high quality and working fine on other systems at this resolution and framerate.
Enabling/disabling hybrid graphics.
Enabling/disabling integrated graphics.
Enabling/disabling Re-BAR.
Ran the GPU UEFI firmware updater in W11, said I had an update available, but this didn't resolve the issue.
Current workaround:
Issues eliminated if only using HDMI from graphics card to monitor. Seems to be an issue with DisplayPort only.
Seems to be an issue with other peoples' graphics card not allowing to boot into UEFI (using the term BIOS above as it's more commonly referred to). NVIDIA released a fw patch for 5060 Tis. https://www.techpowerup.com/337331/...pdate-to-fix-rtx-5060-ti-reboot-black-screens
Ran this updater in W11, said I had an update available, but this didn't resolve the issue.
Im still on 2A31. Its all working fine so I don't want to touch anything.Another new X970E BIOS
- - Improve memory compatibility
- - Optimized Secure Erase mechanism.
