It must be a plastics and earthing thing. Anything metal which is earthed should just dissipate static.I'd like to see an analysis of why modern grinders have static problems - is this just a cheap materials / plastics(insulator) design issue,
it's obviously listed as an issued for df54/60 WHY; I've never had any issues with Rancilio.
It arrived today. Went down to my local coffee shop who kindly grinded a bag of beans for me. Not ideal, but better than nothing!Cheers everyone! I found a refurbished - excellent Duo Temp Pro on eBay for £225, so have grabbed that. Meant to be arriving Monday so I'll give it a go with pre ground beans for a while, and if / when I feel like I need the upgrade the cost of a grinder won't be too galling
I'm learning how to gauge the amount of grounds I need, and how firmly to tamp to get something decent. I've not nailed it yet (and really need some decent scales or a grinder with them built in). But I'm really enjoying learning! I've had far too much caffeine today.
Nice one, thanks! I've been using the "razor" which came with the machine and seems to do a decent job of scraping off along the top. I think I've been slightly overfilling the basket, and perhaps then tamping too hard. I'll try again tomorrow!How much ground....you dont want to overpack it obviously. The ideal way is to put the weight of the beans for the size of the basket, perhaps 1-2g under but never over. So if it is a 18g basket, you can do 17g but avoid going too low like 7g shot.
The less ideal but still kinda work is to put the ground into the portafilter then using the back of the knife do a sweep across the top and remove anything above it. Then use the correct size tamper to press it down. 58mm basket need a 58mm tamper.
The art of basket prep is its own rabbit hole, right now, getting the right amount and making sure you are pressing it down evenly is most important. First you will need the right tool. If you are trying to do it with the back of a spoon, it's not going to work very well as the pressure will be uneven.
Ah, but I've currently relied on the local coffee shop to grind, so I'm having to adjust for that. I may ask for marginally less fine next time!You can't tamp too hard, but you can grind too fine.
He had a separate machine which he uses to grind beans for customers. They're pretty well kitted out!The issue with that is if I were the barista I would be reluctant to change the grind setting for the shop's machine because it is dialed for their espresso machines, rather than yours.
No, it's not choking - the first I made was too watery, so I added more coffee and tamped harder for the second and it only dribbled out. I've now had way too much coffee today so I'll try again in the morning!Oh, handy !
edit - so is it completely choking? or takes like 1 minute to get the correct ratio out? so, 18g aim for 36g of espresso in 30seconds.
				Got a new set of burrs for my Eureka Mignon Silenzio.....amazing how dull the old ones are. Not dialled it in yet, past my caffeine time for the day!
For anyone looking at bottled water, Waitrose Lockhills and Tesco Ashbeck are the same stuff. Waitrose is slightly cheaper if you buy the 4 x 2l pack, but wasteful in terms of plastic usage.I live in a very hard water area and using Tesco Ashbeck water, it's about £1.50 for 5 litres.
