Boeing has spoken.
Part of preliminary report
One of the findings from the report outlines how a pilot could be heard asking the co-pilot in a voice recording of the cockpit in the moments before the crash: why did you cut off?
The report says that both engine fuel cut off switches were turned to "cut-off" with a time delay.
Below is an excerpt of that finding from the preliminary report:
"The aircraft achieved the maximum recorded airspeed of 180 Knots IAS at about 08:08:42 UTC and immediately thereafter, the Engine 1 and Engine 2 fuel cutoff switches transitioned from RUN to CUTOFF position one after another with a time gap of 01 sec.
"The Engine N1 and N2 began to decrease from their take-off values as the fuel supply to the engines was cutoff.
"In the cockpit voice recording, one of the pilots is heard asking the other why did he cutoff. The other pilot responded that he did not do so.""
I know that if a pilot decides to pull these switches there is probably not much that can be done this close to the ground, but as a layperson the fact there's no safeguard against this being possible is pretty shocking. It simply shouldn't be possible to do it, either via software or some kind of hardware feature.
Are the engine fuel cutoff switches next to any controls usually adjusted just after the plane takes off from the runway?
Yikes, not many options left beyond suicide, mental health issues etc?
One of them vibrating to cutoff is plausible but both at the same time?It has quickly also been reported that a Special Airworthiness Information Bulletin (SAIB) (NM-18-33) from 2018 highlighted a possible issue where the switches didn’t lock in position as they should, and they were used on many Boeing aircraft models.
It was not mandatory to do anything and the reports are suggesting it wasn’t looked at on this aircraft.
Dynamic Regulatory System
drs.faa.gov
That two unlocked switches could vibrate to the cutoff position if not fully up is not unfeasible and would explain the pilot’s reactions.
Data from the CVR/FDR.One of them vibrating to cutoff is plausible but both at the same time?
Read the conversation you quoted, I am not disagreeing with you.The CUTOFF switches were clicked engine one first and 1 second later engine two, so were done deliberately (they can't vibrate to any position these baulk type switches).
Possible yes, however the probability of a fault causing that to happen to BOTH switches and a second apart is practically zero.Is it not possible for the switches to physically be in the correct position but somewhere in the mechanics/system to have changed through a fault and they show on the readouts as changed and changed in black box even if no crew actually touched them ? Like to the eye they are in correct position, but everything else shows them as cutoff ?
I've seen this mentioned on some other forums, hoping you could confirm?I hadn't even considered this, it's unthinkable that anyone would take this action. I tried multiple different things in the sim but didn't even bother with this because there could only be one outcome.
Well I've had a copy of the preliminary report for about six hours now so lets just say the plan to not make it public has gone slightly awryInitially reports said the preliminary report wasn't going to be made public but now seeing some reports saying fuel cutoff switches?
Not sure what's correct.
The report is available to anyone on the AAIB India site.
https://aaib.gov.in/What's New Assets/Preliminary Report VT-ANB.pdf
Odd - the thrust levers are at minimum, yet the accident report states one engine was regaining trust, you’d expect one leaver to be forwwrd to command thrust? Or do they mean it had just spun up to minimum?
I see that the relight sequence occured 10 second before the system stopped recording - I have suspected the impact would have been before that point by at least a few seconds.
Fair few do already have CCTV in the passenger areas.It really is time they install cockpit video recorders now on civil airliners as they do on helicopters , so to see which of the pilots is inputting controls or doing anything not normal/incorrect at any time, also if any cockpit intrusions or unauthorised people in the cockpit.
There is zero good reasons not to have these installed in the cockpit and the passenger areas and honestly shocking this has not been done yet, CCTV is a part of life now and especially in public areas and an aeroplane is a public area and transport, even buses and trains have CCTV so why don't aeroplanes ? People even install dash cameras in their cars so to have proof of accidents or events that may happen during journeys.
