Upgrade or new?
27 Aug 2010
Hello,
Probably on my 3rd or 4th pre-built OCUK rig now... current one is about 6 years old
AMD Ryzen 5 2600
Radeon RX Vega 8GB
16GB RAM
Still generally seems to be fine for most stuff, but do get occasional 40FPS / stuttering with more demanding games
Tend to play most Blizzard games, Cyberpunk, Battlefield, Street Fighter 6
I'm also a big Borderlands fan and I'm looking forward to Borderlands 4 - Which I'd like to play on at least high settings.
Should I be looking at upgrading my entire rig or is it worth investing in some new components for my current system?
I'd also like to upgrade my harddrive, which is a paltry 500gb.
Please can I ask for some suggestions / advice?
Cheers,
Tom.
If you're happy with secondhand bargains, you could make a very decent budget AM4 system, something like a 5700X3D, RX 6700XT/6800? Or even pair it with a new 9060XT?
I'm guessing you're fine with 1080P?
Not fussed about the latest and greatest 4k, no.
Would just like a bit more power to turn up the graphics on higher end games and have a solid / reliable 60fps at higher settings.
Thanks.
Thanks.
Nice, yeah then you'll have no trouble building a pretty decent and competent 1080p mid-high system for not too much outlay :)
I'd go 5700X3D secondhand if possible, and a RX 9060XT, keep your ram or the meantime, unless you find a game that needs more - which you won't at 1080P unless you're running loads of mods? But you can upgrade that at any time :)
What is your current motherboard?
I have a B450 Aorus Elite by Gigabyte Tech
You haven't given us a budget as far as I can see but the go for a lot of people to is to upgrade to a 5700X3D and an AMD 9070 XT if you want excellent bang for the buck.
You'd need to let us know what PSU you have currently as if it's under a certain wattage, you may need to upgrade it too.
FYI: Update your BIOS to the latest version before you upgrade anything.
I used to practice a 2-3y upgrade cycle within a socket or mobo constraints, but lately technology has been moving quicker so you can get so much more milage with 2nd hand upgrades for much lower budget but with a bit bigger rebuild.
I think you need to realistically set a target for how much you're prepared to pend so folks here can give you good advice.
Budgetwise... I was prepared to start with a whole new rig, where I'd usually spend £1200-1500.
But if upgrades are worthwhile, then I'm happy to do that.
I guess it would be cool to get a new CPU/GPU and a bigger hard drive for about £600? I guess the cheaper the better :)
I think RAM is reasonably cheap now isn't it? I could always upgrade that later if needed.
Thanks for all your help so far.
We can do both specs, a new build for £1200-£1500 and an upgrade to CPU/GPU/SSD for £600.
For the upgrade spec, need to know the case and the PSU.
DDR5 is still relatively cheap, but DDR4 (at least, new) has gone up a lot recently.
16GB ram will be fine for 1080P unless you're using loads of mods?
secondhand or new 5700X3D + 9060XT, whatever SSD/NVME/HDD you fancy. Job jobbed, unless you want to or need a new PSU.
Upgrade ram with secondhand as and when you need it - I haven't had an issue playing anything with 16GB ram, STALKER 2 and all the UE5 games played fine at max settings native 1440P or 4K DLSS, then I got 32GB and haven't seen the benefit, yet. I don't really do many mods, the odd tweak here and there. So take from that what you will.
The PSU is terrible, if you're going to upgrade anything get a new PSU first.
If you can afford a new AM5 PC - definitely go with that. Sell the old one on eBay.
Am I better off just going for something new then?
This seems to fit tick all the boxes...
My basket at OcUK:
Total: £1,099.99 (includes delivery: £0.00)​
I would just fit a £200 5700X3D into your B450M motherboard, buy a decent 850W PSU, a 9060XT, and upgrade the ram with a 32GB secondhand kit as and when you need it... You'd be well under budget versus that pre-built.
