Road Cycling
Yeah, i'm quite proud of myself to be honest.
My only slight concern is the fork length. I won't want to cut anything until i know what frame they'll end up on. Could result in some hilarious spacer placement. But the head tube length on the Mondraker Arid is shorter than my X Gravel, so in theory it won't be a problem.
My other logical reason for doing this. If i ended up buying a completed bike in the sales or even used. It's unlikely to come with a suspension fork or carbon wheels, so i'd want to replace those anyway, even if i bought something like this
yeah, the only bikes I've seen currently with suspension fork are some of the boardman range - ali frames for £2k, some of the new ribbles have it as option and canyon new grizl has it too.. I think majority use the same fork with 40mm travel. Canyon may be the special one as it has a lockout on the handlebars to lock the fork.
Yeah, the Canyon uses a DT Swiss fork i think. Unsure if it's proprietary for Canyon or available to all
Yeah the metal wire has snapped. I did hear you can get replacement parts so I'll look into that. Can't hurt to have two pairs anyway!
I was really, really tempted to get the white ones but I played it safe and went for black
just go on the website fill in a few details and they'll send out a few replacements.
fair few gravel bikes offering suspension nowadays, most of the main manufactuers have one. Giant Revolt X, Cannondale Topstone Lefty, Canyon Grizl and Grail now (the DT Swiss fork is exclusive for 2025 to Canyon).
@Vandle You were wrong. Turns out riding an ebike is a lot harder after all.
Especially when you convert a bike, change your chainring from 32T to 44T, add a motor and battery adding around 8kg and then get 10 miles away from home and the battery dies on you. So you've got rubbish gearing and extra weight.
:D Sounds fun!
I haven't ever ridden one so my opinion isn't worth much however I don't think the argument was ever that riding an Ebike is harder or easier. I think it was that an Ebike will make you fitter as you can turn off the assistance to make things harder, the counter to that being you can always find a harder gear, a bigger hill and change up your cadence to do the same on a road bike.
Ebikes are great for those who are currently physically challenged through age, illness or otherwise and are building fitness slowly. I can imagine on a daily commute for example turning off the assistance at an earlier point each day and the satisfaction of seeing how your body is adapting to it after some health set backs, absolutely brilliant for those people and there is no chance I would argue against the benefits of that. I may well be in the same position in years to come.
There's no chance you couldn't have bettered today’s average HR and energy output on a road bike though. :)
:D Sounds fun!
Ah maybe i'd just forgotten the argument.
Absolutely i couldn't have had a harder workout on my regular bike so still maintain you're right on being able to recreate equally hard situations through gearing. The added weight isn't *that* bad to turn it into an effective training device. For me the benefit is mainly two fold
1 - Get time on saddle in the mountains without killing myself. It's relatively mountainous here with steep inclines. I don't (yet) have the strength to nail them without extreme fatigue and when i do it's horrendously slow. Going at a decent pace means i can cover 100km instead of 70km for exploration purposes
2 - Trips to the pub with the wife in the heat, mean i can finally turn up without dripping with sweat!
I totally see the argument for eBikes but I'll stick by the argument of them being generally easier to ride for the masses.
When I'm being critical about eBikes it's not in cases where it makes a lot of sense like a cargo bike but more the ones that for all intents and purposes looks like a road bike but has a hidden motor within it.
But I'm just some clueless judgemental **** on the internet :D
Really bummed out about my shoes being a little too tight as it's quite sunny today and would've been a decent test. Quite tempted to take them for a trial run but I'm 99% sure that the next size up will be a better fit.
Most places should exchange for sizing, unless you've got them dirty or marked them fitting cleats...!?
Been thinking, the Specialized S-Works 6 I got as a bit of 'test' to judge the fit on, have rubbed my ankle bone and not happy with how tight the heels are. So won't be buying a new pair or trying a Wide. Fizik too tight (pair to bin). Bont too tight (pair to flog). Not that impressed with Lake (for a race shoe too flexy - my pair have a 'clicky' cleat mount so turbo only). Back to Sidi I guess (EU42 set of Kaos now 8 years old are still going strong), unless I find some more premium Specialized Torch or Giro. The cheaper pairs I've used+abused+killed of those commuting didn't last very long (couple of years+winters). I probably need to look for replaceable heels as that's what generally wears out on them. Cleat covers work well for the school pickup, but puts more pressure on heels walking home! :rolleyes:
What other brands should I be looking for - generally size up a little wide (or have a wide fit), with lots of colour & fastening options, that don't cost £200+ for a standard shoe!
but yeah, I'm not paying boardman again, their finish is not good in my opinion, crap paint and assembly with discs coming loose, caliper coming loose etc.. from factory.
Oh yeah forgot you'd had build/loose fitting issues. Was that buying direct from them boxed or built somewhere else?
No, separate free bodies which is an annoyance i've found in the past!
Yeah although SRAM and Shimano freehubs not interchangeable - so cassettes are different - the chains actually are providing you match number of gears. I'm running 11s SRAM chains on Shimano cassettes & chainrings. Just make sure you know if XDR or XD - as they are different...
So technically you could ride a 'SRAM wheel+casssette' on a Shimano front chainring+chain with no issue like you're thinking. Just be aware of the 'frame spacing' for the hub which should both be 142mm (if it's not you might be able to solve with hub endcaps) in most cases and the chainline then being a bit off if mixing/matching which you can get around with indexing.
12s is fine too. Basically shifting might 'not be as smooth' as running all of the same brand. But providing you match the speeds should be ok 'technically' with some fiddling/indexing and possibly increased wear on things.
Good workout! Plan a hilly long circular ride, where you do all the hills on the way out, expect to run your battery out, then ride home a flatter route without assist! ;)
Can't say I notice a huge difference in efforts between my 8kg and 11.5kg bikes, certainly not on short sharp hills. Better bike flexes less but not convinced the weight really that much quicker uphill (the 76kg motor on top has the same output) :D
you and me really are the problem here.. it's a road cycling thread for 23 and maybe 25mm tyre owners on a good day!
we come here, with our suspensions, 45mm tires and ebike ideas. PSH. filth.
Suddenly me riding my Gravel bike on the road and saying how much I enjoy 28mm tyres the last 10 years is normal and accepted! My battle is won! :D
Even some e-road bike talk being allowed! Just be careful of your e-gravel chat ;)
I just wore them cleatless for ~30 minutes and could tell they wouldn't be pleasant to cycle in. I ordered another pair in white but 1/2 a size up. They've been delivered by Amazon... to the wrong house lol. So I'm going to try and get those on my way home then send back which ever pair fits worse.
There is a part of me so angry at Amazon I'm tempted to be very non-ethical and collect them from the wrong house and say I never got them for a refund. But then my goody-two-shoes side thinks that would just cause issues for the house that it got sent to. :cry:
Maybe consider something like this for commuting/school pickup?
Then just wear normal trainers
Got the white ones and they're far too big. Which makes me think that maybe I'm just not used to the second skin feeling of the ones in my size
Also think they look much nicer in black
