- 13 Sep 2010
Thought I could still upgrade my W10 key to 11? - If they've pulled to rug on that then I'm even more annoyed about the whole ordeal! I haven't paid for Windows since I bought XP Pro SP2 for £16.Haha, I was going to say he's ballsy running the risk 15 days after the EOL
Ah nasty, I just use Rufus to remove that requirement along with TPM. As for OneDrive, that's the first thing I disable then uninstall
Are you not tempted to just buy a cheap key elsewhere for W11 and be done with it, and then run off into the unix sunset
Yeah that makes sense, you can't really loose whichever distro you use if it works for you, then it works, I haven't used Bazzite myself, but I was under the impression it does a lot of it for you/is already nearly ready to go, so less faff/learning?
Current W10 Pro install was upgraded from a 7 pro license that I got free when I was a student around 15 years ago
