OMG look at those clay "bricks" we don't use them in the UK so its 100% going to fall down
I may have missed this earlier in the thread but I think you recently mentioned this was off-grid and were going solar/battery? What's the deal with water and sewage? Will you be connected to a mains supply or is it provided by a well/water storage from somewhere and is it going to be a septic tank type setup for sewage?
RO Units are, as you say, very wasteful if you can't put the 'waste' water to good use (i.e. storage/irrigation). I used to keep marine fish and had a 100 gallons per day unit (with a Total Dissolved Solids meter). The filters were replaced annually, usually around £50 for the 4 pot unit I had. I see that there's a company that does Filtration units for Canal water for Canal boats, not sure on costs, that produces drinking quality water from Canal water.
So how are you planning to shower etc? Use the irrigation water?Yeah off grid with solar/battery.
Sewage will be via septic tank
Water is an odd one. We have water supplied to the plot, but it is only intended for irrigation and so is untreated. We're exploring various options for water filtration.
Reverse Osmosis is a possibility and in theory would make it drinkable. However my wife has made it clear that no matter how pure the output, she will not drink anything out the tap! The other option is just a 4 stage filtration to clear out any nasties and make it suitable for cooking/cleaning. Reverse Osmosis is very wasteful which isn't very environmentally friendly and given the supply issues in Spain i'm not too keen on that.
Yeah, i'm fine to drink it, my wife just thinks it's dirty no matter what.
You could get it tested and show that it's perfectly safe. Having said that, bottled water for drinking in Spain is so much cheaper than the UK.
Agree 100%. My Spanish sister in law took ages before she was happy to drink UK tap water.Honestly i've told her it'd end up being the cleanest purest water she'd ever drink and it doesn't matter
My goal would be to use it for drinking because otherwise you're consuming loads of microplastics and creating huge plastic waste. Especially as i'm lazy and buy the 2L bottles instead of the 8L ones and decant into smaller ones.
