'Edit' confirmed by Glanza belowDoes anyone know if the rear fans with the cover have enough spacing to fit 30mm think fans? Other than putting them on the inside?
Hi mate its covered in this videoi am looking to order one today with new Fans as the ones in my current build where just cheap and nasty but do a job. The question is whats the best way to get best airflow in there.
I have a AIO so want to replace those fans as well to make it all match.
how many reverse fans should i get ?
Cheers
Cheers
Thanks for this will defo take a look on dinner.Hi mate its covered in this video
I ended up using 4 reverse fans but if you had them at the bottom and side you would need 7
Yeah it looks amazing when its filled out with fans although i do have 2 SSD and 1 HDD to fit so am guessing am leaving the HDD tray in but still should look amazingI don't think it's really about airflow. That may seem like an odd thing to say, but one or two fans is just fine for airflow. The rest are for looks. I mean if you want raw airflow then this isn't the best case to get. It sure does look the best though!!!
Maybe when removing the clear side/front panel just be careful as it comes out forward and up at the same time but after removing it and putting it back a few times you will be fine Enjoy the case mate.Just ordered one of these HS420 from OCUK, Anything i should know?
I did see on a clip somewhere that there was an issue mounting certain 140MM fans, But no issues with 120MM (Which il be using anyway)
Really appreciate the heads up, Thanks!Maybe when removing the clear side/front panel just be careful as it comes out forward and up at the same time but after removing it and putting it back a few times you will be fine Enjoy the case mate.
