Upgrade vs New Build: Old and older m-ITX!
27 Jul 2025
UK
Hi folks,
I'm looking to upgrade or replace two m-ITX PCs in a few months time (as the weather starts to turn bad) so right now I'm looking for high level advice to set budget requirements/expectations or perhaps to keep an eye out for 2nd hand parts for the older machine... if that's worthwhile!
Use-case: I'm looking to upgrade or build for gaming at 3440x1440 with settings on max. quality. I don't feel the need for FPS >60. Examples of games currently in Steam wishlist or regularly played: RDR/RDR2, Atomfall, HoI4, TW series, OMD3/4, KCD1/2. My intention, after dual booting for >10 years, is to finally ditch Windows completely and solely use Linux (thanks to what seem to be really solid advances driven by Valve and others). Perhaps this means a little more grunt is asked of the system though for some games?
Machine 1: B550M-ITX/ac mobo with Ryzen 7 3700X, 16GB RAM and RTX 2060 SUPER. Housed in NXZT H1 with a 650W PSU.
Machine 2: i5-3570K, 8GB RAM and GTX 670 FTW. Housed in a Shuttle FZ77 (SZ77R5) with a 500W PSU.
Both systems have (SATA) SSD for OS and HDD for games.
Perhaps an M.2 SSD for Machine 2? Would I see a worthwhile difference if dropped ~£250 on a replacement GPU for this?
What are folks thoughts on Machine 1 - simply too old to upgrade to perform the use case described or is there life in the old dog yet?
TIA
Hi folks,
TIA
Honestly I'd not bother with the 3570K system at all.
Easiest thing you could do with the AM4 would be to grab a 5700X3D for around £180-200 and then upgrade the GPU to a minimum of a 9060XT 16GB, faster budget allowing but that would be the bare minimum I'd consider.
Probably worth upping the RAM to 32gb too.
Do you know the exact models of the PSU's? The wattage alone doesn't tell us much as quality between units can vary greatly, your overall budget would be helpful too.
Thanks Gray.
The PSUs both came with the cases. Machine 1 is 650W 80 Plus Gold, Machine 2 is 500W 80 Plus - some more description on links but no brand name or anything like that.
Historically I'd probably spend something like £1-1.2k on a new build, e.g. to replace #1 (just the machine, no monitor/peripherals) and am essentially I'm wondering if it's worth spending a few hundred on upgrades to delay that for Machine 2 or whether it's better to start from scratch with both machines. A 5700X3D plus a 9060XT 16GB look like they'd be around £500-550.... consideration is best bang for buck more than actual number of bucks.
Thanks Gray.
AM4 is still a strong platform and going with the 5700X3D would see serious uplift, it's difficult to manage that with an ITX build especially so upgrading to AM5 is off the table.
For 1.2K I'd do the following:
My basket at OcUK:
Total: £897.97 (includes delivery: £7.99)​
It's not worth spending more as it would require you to do a total rebuild, the PSU you have is competent for a 5070ti, worst case scenario you'll need to undervolt it.
As mentioned earlier up to 32gb of RAM too.
Make sure the card will fit your case.
System 1 well worth upgrading and the options above are great.
I was all for upgrading to a 4090/5090 and even had a case and PSU waiting. Then DLSS (FSR is also improving) got so good it just doesn't seem worth upgrading beyond my RTX 4080 except maybe get a 5xxx/6xxx series card that can do multi-frame insertion.
I'd rather spend £700-900 on a good OLED HDR monitor than £2K on a GPU and not get the best out of it.
Thanks for the advice so far folks.
In looking at the card Gray found (looks like a good price with the discount on it right now) I noticed that the link to the H1 case is for the v2 whereas I have the v1. I found a review of the v1 here but also dug out the leaflet that came with it and:
  • The 650W PSU is correct for my v1 (the v2 has 750W). Mine has model info NZXT NP-S650M.
  • The max. GPU size is different for v1 and v2 though, with a max. length of 302mm for mine. Doing a quick search this shorter length restriction pushes the price for that 5070 Ti right up! :(
There seem to be a few more options for the 5060 Ti though... e.g. this one for £400 vs the 5070Ti for £680... is the performance change really as dramatic as that price drop?
Amd 9070 16gb card for £500 prob a good option for 1440p gaming...uses 220w max power (5060ti 16gb is 180w but lower than 5070ti/9070xt 300/304w max power). relative perfomance is 41% faster than the 5060ti 16gb(linked relative performance of the 5060ti below, just scroll up to see the 9070)
My basket at OcUK:
Total: £499.99 (includes delivery: £0.00)​
My basket at OcUK:
It's a little too large unfortunately.
Shame the 5070 Super isn't out yet as it'll almost certainly have twin fan models, along with more VRAM if the rumours are true.
My basket at OcUK:
Total: £1,176.97 (includes delivery: £7.99)​
These Acer models are 295mm in length, I don't know much about them though.
£560 (incl. VAT)
£489 (incl. VAT)
£620 (incl. VAT)
£500 (incl. VAT)
£750 (incl. VAT)
£600 (incl. VAT)
My basket at OcUK:
yeah, didn't check length to be fair but then a £500 gpu cmpared to a £680 gpu(£5070ti), leaves a little room to change the case ..or actually, just get a shorter gpu even if slightly more expensive...cheaper :cry:
thought quick look at say card is 289 x 111 x 41 mm / 304 x 127 x 42 mm (w/bracket) (what's the with bracket? as without looks like it'll just go if max length is 302 allowable) though max legth for v1 case is 305mm from online look
Thanks again for all your inputs. I'm thinking I'll do a few things across multiple steps over the coming few months:
1) Next week/10 days upgrade Machine 1's GPU to a 5060 Ti (looks like best bang for the buck, lower power draw/heat than £500 9070s). The Asus GeForce RTX 5060 Ti Prime 16GB is £430 at oc.uk and looks like it'll just fit and with 3 fans will hopefully be quieter than the 2 fan stubby cards. I'll then put the existing 2060 Super into Machine 2 to replace the GTX 670. Also add a 2TB Samsung 990 PRO NVMe to Machine 2 (Mobo has a heatsink waiting for it).
2) See how that works out but plan to put a 5700X3D into Machine 2 in a month or two to complete that upgrade.
3) In the late autumn/early winter do a complete new build that will replace Machine 2. Already eyeing up the Louqe Raw S1 as the starting point for that :)
If you buy Zen 5000 I’d probably pick up A620 board and 32GB of cheap DDR4, then use 3700X and 16gb of RAM to upgrade the i5 system.
