Anyone got or playing around with a Zwift Ride (and Kickr Core)?
Getting twitchy, and thinking about upgrading my old Atom first gen. Can still get decent money for them (if serviced well), so playing with options. The reviews all seem super positive.
The riders I know who've got the Ride seem to love it - plenty of them coming from - or even having alongside Smartbikes/Wattbikes. Especially if you have an old Atom and feel you can get money for it, hard to say not to...
Really if my Kickr v5 was compatible with the Cog I'd probably go the Ride route, but as it's not, I'll be staying on my alloy frame with Di2 and shifting (then have to deal with the 'pain' of BT on AppleTV to keep steering - which I'm mostly working around these days anyway without too much issue). I think I'm pretty much locked in until my KICKRv5 dies, got it start of 2022 and it's had zero issues. Probably needs a bit of a clean & service (as does my bike & likely needs a BB & chain), but at £699 I got a mega deal I'm at the point I've had my moneys worth out of it - while it also not enough value selling it to upgrade. It always irked me they made the older Core's 'better' as they're Cog compatible, then the Premium KICKR misses the physical hardware so no firmware update can help it... But it did come out at a time when Wahoo where at odds with Zwift and bought in with RGT to directly compete. Meh.
@Vandle that's good to hear. They certainly seem to get rave reviews. The only thing I'm trying to figure out is what you don't get by having the Kickr Core (and not the 'full spec' Kickr).
Lighter flywheel 5.4kg vs 7.2kg (only marginal when considering the Ride+Hub for gearing)
KICKR more stable - the legs spread wider and it's heavier (likely no impact for you as not a massive heavy sprinter)
Core has less gradient simulation - 16% vs 20% (really no difference)
Core is Wireless only, no DirectConnect adaptor so you can't use '
Race Mode' (no real difference to most riders - I've not even bothered to use it)
Core has less maximum wattage - no difference for you (1800W vs 2000W lol)
Really the amount the Core gives you there's no comparison, especially when bought together as the Zwift Ride+Cog bundle, along with the massive price reduction Wahoo did on them... I wouldn't advise anyone to buy a full Kickr these days (probably why they made it the ' KICKR MOVE' and not just a Kickr v7).
