- 2 Aug 2016
- Third Earth
I’m colourblind so no idea, but to my eye it looks great!Is it rorange?
Melbournerot.
Melbournerot.
The irony of the oil rigs in the background
How do you think plastic is made?
Erm, no. Several trims of Mustang come with the pony black.Barry Focus ST vibes with that grille
4D plate next
Maybe so but chrome looks way better, in my opinion of course. As long as you’re happy with it that’s all that matters.Erm, no. Several trims of Mustang come with the pony black.
That cliff was more of a mound to begin with though, let’s be honest - P Zeros are not particularly strong in that regard![]()
I work at motorsport and performance if you need anything let me knowPushed the wheels out 20mm at the back and 25mm at the front. Much better. I had to trim the studs on the rear wheel hub to get the 20mm spacer on. A common issue. Only. needed to take 1mm off.
Also Plastidipped the pony on the grille. I figured that if I didn't like it I could just peel it off. I like it.
Next on the list are some Steeda progressive springs (25mm drop at the back, 30mm at the front) and a subframe alignment kit + support bushes. Not sure whether I'm going to do those myself or pay someone to do it. It looks simple enough but I really don’t like working under the car on stands.
would love for you to come sample our S550 and RTR s650 pal , also need any bits for that pony let me knowHi there
Back to where it all started - back in a Mustang!
A one owner, low mileage Grabber Orange Shelby GT500, collecting later this week!
5.4l iron block, 500HP stock.
Will no doubt start power mods next year, car has a full Griggs adjustable coil over suspension setup.
$1500 will take it from 500HP to 650HP (CAI, Pulley & Tune)
$3000 SC swap will take it from 650-800HP
New pistons, injectors, fuel pump and drop pulley on SC swap and looking at 1000HP.
I will probably stop at 650HP, be more than enough in such an old beast, but I loved my Saleen and far preferred it over newer S550 I owned, so when this came along, it had to be done.![]()
