We are in the UK, not the US, we don't buy GPU's from the US so i'm just not going to debate you on that basis. This is a UK forum with UK people looking to buy UK GPU's. Currently the 9070 starts at £500 with the 5060 Ti 16GB starting at £400.
For being 25% more expensive its 50% faster in raster and 44% faster in RT at 1440P. Either way you're getting more FPS for your money, a lot more, the difference in performance is huge.....
As for the 9060 XT 16GB it starts at £330, the 5060 Ti 16GB for £400 is 5% faster in raster and 5% faster in RT at 1440P, the price difference is 21%.
The days where Nvidia have a huge advantage in RT are gone. So now its all about 4X Frame Gen, something i have too and i don't need games to support it, not that i ever use it...
Contains the 9060 XT 16GB, the 5060 Ti 16GB and the 9070.
The Sapphire Radeon RX 9060 XT 16 GB sells close to MSRP, yet it features a factory overclock and higher power limit. In our testing, its cooler remained whisper-quiet even at full load. Interestingly, this model uses Samsung memory, whereas all other cards we've tested so far use Hynix.
www.techpowerup.com
If my budget was £500 or less it would be the 9070, if its £400 or less it would be the 9060 XT 16GB, it in my view is actually in a difference price bracket, its in the £300 to £350 bracket. Yes the 9070 is also in a different price bracket to the 5060 Ti 16GB, i agree, its also exploiting the £400 to £450 price bracket in which AMD are missing in action, a bit of an oversight on their part.
I think the 9070 for the level of performance you're getting £500 is not bad, its about the same price as the RX 7800 XT was and its about 30% faster in raster and 50% faster in RT, its about what to expect from a generational upgrade, well if you're not looking at Nvidia, sorry but true....
The 5060 Ti 16GB is not a good GPU, it doesn't have great performance in raster or RT and its a bit pricy for that... for £350? Yeah, that would be fine, it would be a better buy than the 9060 XT 16GB. Its slower than my previous gen card, Jesus.... How can anyone think this is a good GPU to blow £400 or more on?
