Upgrading my PC
21 Oct 2019
Hey everyone
Need a little help in choosing the next PC upgrade.
I'll only be gaming on my PC and nothing else. I've been an Intel guy since day dot so all I've known is that. Never been torn away as it's always been reliable
I have tried to research but get a little lost in all the tech talk.
I have came up with this for now, I'm sure you'll change what you think is necessary and if there is something better or equivalent than me spending over the odds for something I don't need.
Price wise, yes I'd love it cheaper but I'd be happier around the 2k
I have a monitor ATM which I'll still use - 27"
I have been looking though for maybe a wide-screen 32"/34"? If you'd like to maybe suggest?
That would also be very nice of you ‍♂️
Hopefully that works
Many thanks ☺️
Then you'll be sad to know that Intel Raptor Lake (aka what the CPU you've chosen is) has well known problems with degradation, there's a fair chance you could run into problems with it and even die hard Intel fans are loathe to recommend them due to the fact. As far as we know the follow on series (Core Ultra) doesn't have those problems, but is so-so as a gaming CPU compared to even the prior generation.
That aside there's some iffy choices, a lot of unnecessary money on some components.
I take it that your budget is in the region of £2400-2500 or would you be willing to spend more?
What is the exact specification of your current PC?
My basket at OcUK:
Total: £1,804.86 (includes delivery: £11.98)​
This would be faster than what you selected for a £500 or so less, you could spend another £200 and get the 9800X3D which is more powerful but not necessarily worth the cost.
The T500 will be just as fast as the more costly drive you selected for gaming, you're not benefiting from a high speed gen 5 drive.
The Thermalright AiO will perform just as well at a fraction of the cost as that NZXT model you selected for £200.
AMD is by far the strongest option right now for pure gaming, and has proven to be a lot more reliable than Intel over the past few years.
If you really wanted to push the boat out into the £2500 or so range you'd be better off going with what I've listed and ponying up another £200 to fit in a 5090, which is substantially faster than the 5080.
Cheers for the quick reply
Obviously I'd go for AMD if that's better as a gaming rig. I've just never had a problem or issue with Intel
I'd like it to be around the 2k mark but I'm open to suggestions.
I would really like the PC to last me more than say 5 years without having to upgrade it.
My current PC is as follows
I7 10700 3.80GHz
3080
32 GB Ram Team Group 3600MHz
1TB WD Red X2 I think
Fractal 360 cooling fans
MSI motherboard
Aorus AD27QD monitor
I edited/listed a build idea in my initial post that should fit the bill.
You could save more on the PSU too tbh, a good 850w version of the AMP for around £90-100 would be ample for the build, but the 1000w Platinum model is pretty well priced, I'd happily move that thing into another build after 5 years.
It's M-ATX but that's just a personal preference, you could move to a different ATX supporting case and appropriate motherboard for around the same money.
It's a shame regarding the Intel chips, Raptor Lake is actually a solid CPU series outside of the degradation problems and just aren't worth the risk, and as mentioned the new Core Ultra series is underwhelming in gaming but can be really good for work/productivity.
It doesn't make sense to buy a 14900KF at this point, with big question marks over how long they will last and the potential power/heat you'd have to deal with.
If you're set on Intel, I'd go for a 265K. They're decently priced with the recent price cuts and though the 14900K/KF is a faster gaming CPU overall, you're unlikely to notice the difference at a higher resolution.
The best gaming CPU right now is the 9800X3D, but that's AMD.
I don't know if you're going for a white build or not, let us know.
Don't buy a monitor I suggest, I can't recommend one.
My basket at OcUK:
Total: £1,963.87 (includes delivery: £0.00)​
I appreciate the info
No I'm not 100% with Intel and can be persuaded to switch and go for AMD if that's purely based on a gaming PC.
I've just always had Intel
The 9800X3D would be the better option and I wouldn't mind paying that little bit extra to get the better running PC
Again white isn't a preference tbh just looked at certain PC's that had the best air flows. Again I've always liked NZXT.
If there is something better out there I'm all ears
What's the difference between the graphics cards other than massive price difference? Are Nvidia way better than AMD or is that not the case?
Many thanks again
The 5080 is faster by around 15-20%, the 9070XT is roughly as quick in raw performance as a 5070ti.
The differences between Nvidia and AMD mainly are that Nvidia has DLSS upscaling whereas AMD has FSR, the 9000 series cards supporting FSR 4. The problem there being that FSR4 isn't as well supported or quite as good (although there's not much between them), there are workarounds to get FSR4 in most games but they're not perfect and can even trigger anti-cheat software. After that Nvidia also offers superior ray/path tracing, which is becoming more and more prevalent with some games even requiring it to be on such as the latest Doom.
That said, the 9070XT can be had for £600 and the 5070ti for around £680, I'd struggle to recommend the 5070ti over the AMD card, let alone spending a lot more money for an arguably minor increase to the 5080. However, if you intend to keep this system for 5 years without any upgrades that 15-20% could go a long way.
Here's an ATX build with a 7800X3D and a 5080.
Same comment about the monitor as before, I can't recommend anything.
Personally, I'd spend another £100-£250+ to fit different parts (e.g. PCI-E 5.0 capable motherboard, higher capacity memory, higher-end SSD, 1000 watt PSU, maybe a different/better monitor), because I'm skimping on almost everything to get it under £2000. If it HAD to be under, I'd consider keeping your monitor for awhile longer.
My basket at OcUK:
Total: £1,998.83 (includes delivery: £0.00)​
Some changes I'd suggest:
My basket at OcUK:
Total: £557.96 (includes delivery: £0.00)​
The 216 is a bigger case with higher stock cooling capacity, personally I'd consider that more suitable for a 5080 build, though I'm sure the 207 could handle it if suitably kitted out.
6400 is often achievable with 9000 CPUs, but my understanding is that 6000 is a safe bet for 90+% of CPUs, whereas 6400 is trickier. If you're happy to make some manual changes then not a big deal. Since the X3D doesn't suffer much from slower RAM, I went for saving the money instead.
In most cases, gamers don't see much benefit from PCIE drives when in game. If I were to do it, I'd maybe go 1TB PCIE 5.0 for the primary and get a 2TB or 4TB PCIE 4.0 for the secondary. I'm not sure if streaming is likely to cause hitches/stutters with gaming simultaneously, I guess it would depend on if you're recording?
Motherboard: I haven't done much comparison between the two boards, but usually USB4 is the main benefit of X870 versus B850, so if you can't see anything missing that you care about, I'd save the money.
I should actually say also is that I'm wanting Overclockers to build this rig for me too.
I'm getting lazy in my old age ‍♂️
Not a problem, but it is likely going to push the budget to £2500+ with your build.
We could do a new spec with cheaper parts, like a 265K or 7800X3D and a 5070 Ti.
Ohhh lovely again, thank you
I like a smaller case than the big mid one I have already. I like to condense if I can.
I'm happy to go with the 207 without the digital to save that extra £20 or so
I do like to keep the GPU & CPU
As for the others, I'm more than happy to save the pennies if it keeps the performance and speed at a cost of the money.
Who wouldn't right, no point paying over the odds for no greater performance or speed.
So I could be tempted to change the RAM and storage
I did also add the thermalright frozen in there too.
I did look at that motherboard but I opted for the pricey one instead for some reason
I think it was the 1 DP and I use 2 monitors ATM
Many thanks ‍♂️
I'm confused by that, were you planning to run one from the motherboard? You'd normally just plug them both into the graphics card.
