Glyphosate doesn't penetrate the waxy layer on marestail.I’ve never had an issue with glyphosate, mix it up, spray, stuff dies.
No it’s not instant but nothing really is.
how did you get on with your marestail? Which product did you end up sticking with?Glyphosate doesn't penetrate the waxy layer on marestail.
Glyphosate works fine if combined with some of this:how did you get on with your marestail? Which product did you end up sticking with?
All dead within 2 weeks using Triclopyr. With the bonus it doesn't kill stuff like grass so you can spray your lawn, unlike the suggestion above which would kill everything.how did you get on with your marestail? Which product did you end up sticking with?
Looking for recommendations on a good weed killer that wont kill grass
I've already got a good strong one "Rootblast" that literally kills everything but needing something to sort of the grass areas. Its a rental property so doing a lawn refresh isnt in the budget, i just want it to look a bit better.
Clearly not the best then?Best stuff for Marestail is Ammonium Sulphamate Crystals. Kills it dead within a few days. Usually stays dead till the following year, where it sprouts up in another location.
Repeated dosing with glyphosate worked for me but it needs more than one goYou'll have a hard time getting rid of mares tail... Their roots can be upto 2m deep and their structure makes it hard for weedkiller to be absorbed![]()
Purple flowers? Looks like selfheal (prunella vulgaris)The Vitax weed and feed has arrived, so now got the sprinkler going for a couple of hours then will give it a go.
It can't be any worse than the hopeless greenforce I've already tried (although it did kill some moss).
I'm aiming to get rid of this stuff, whatever it is?..
As I said a couple of posts up Triclopyr doesn't kill grass and kills mares tail.I need this too
I've got weeds everywhere but I need something that won't kill grass or plants. The stuff I've got now kills everything
I've also got moss growing on paved areas and fences, and I need something that kills moss only, the stuff I've got now kills the moss dead but it all kills everything it touches due to it containing bleach
Did you mix it with a bit of sugar -Have to say I am lucky to be here. You don't think it's dangerous when you are a kid.I miss the days of sodium chlorate kill any weed and £2.50 for 1kg tub great for paths/drives , though down side it would kill everything including the user![]()
Yeah this stuff is actually great.Best stuff for Marestail is Ammonium Sulphamate Crystals. Kills it dead within a few days. Usually stays dead till the following year, where it sprouts up in another location.
I tried Greenforce and Westland weed and feed. Still have some broad leaf weeds, a few different types.Something like Greenforce or standard Weedol should do the job.
Stop looking at different brands and focus on the active ingredients you require. Either Glyphosate or Triclopyr will deal with almost anything.I tried Greenforce and Westland weed and feed. Still have some broad leaf weeds, a few different types.
Any more suggestions?
They're different chemicals not just different brands...Stop looking at different brands and focus on the active ingredients you require. Either Glyphosate or Triclopyr will deal with almost anything.
Have a look on Green-care instead e.g.They're different chemicals not just different brands...
I have Glyphos but it killed my lawn once already.
I will tri the triclopyr.
Brands also help because it makes it easier to search for. I tried 2-4-d earlier and came up with not much, on Amazon at least.
Thanks, I'll post some weed photos tomorrow for advice before I commit.Have a look on Green-care instead e.g.
Buy Dicophar 1L online from GreenCare
Enforcer is a 4-way selective herbicide that controls weeds such asspeedwell, daisy, dandelion, buttercup, clover and dock in Amenity Turf, Lawns and Sports Turf.green-care.co.uk
