Just wondering if I'm being unlucky, about 18 months ago I bought 4 8tb seagate drives for a couple of new builds (in four separate purchases from 2 retailers over about 6 weeks), so far I've had a 50% failure rate with the same symptoms, basically reading/writing to them becomes intermittently slow at first, then slows right down until the drive starts getting "reset to raid port" by controller. Running seatools self diagnosics either shows no reported problem at first, then it'll just self abort as the issue gets worse.
Finally they just stop being recognised by the computer as being there at all (they don't show up in the bios, they don't show up in another computer, they don't show up on an external caddy).
With both failures it was at about the point they hit 75% of capacity.
These are drives with the specifc details of
Model: ST8000DM004
PN: 2U9188-300
FW0001
My guess is it's the control board on the drive is failing for some reason, given it seems to be able to still read for a while, but just slows right down.
I'm wondering if it's me be very unlucky, or there is a possible problem with a batch of them, I'm having flashbacks to some Samsung 120gb drives I bought way back, IIRC i had about 9 RMA's in 3 years for the 4 I bought (I've not actually had a drive fail at under 5 years old in ~10 years now).
They are all warranty expiring in 12/2025.
On the plus side Seagate's warrenty turn around is very fast, they received one drive and basically sent the replacement out same day.
I've had the computer pulling off data from one of the drives for the last week until it finally died this morning, at data rates of a stunning 500bytes per second at times
(I've got almost everything backed up on other drives).
Model: ST8000DM004
PN: 2U9188-300
FW0001
