What do you think ?
I think you're over thinking it, unless you are chasing synthetic benchmark figures.
What do you think ?
Not sure if mine is gen 4 or 5 but its pci 4.0 so I'm guessing 4 and... it gets hot. Really hot. Not sure if its the capacity (4tb) but my other 2tb drives run cooler. Swapped it around in several sockets before I found one thats reasonable but its still 69c at idle and it creeps up over time (other slot hit over 100c, ouch) and thats with the mobo heatsink screwed down (yes I removed the protective plastic)Gen5 run hot, Gen4 not as much. With decent case airflow and no obstructions you should be ok, worst case scenario you can always buy an NVME heatsink searately and stick it on your drive if you're finding it gets hot.
Well I got a partial answer to that it turns out there are two main chips on the pcb a large square one that seems to be the nand memory and a much smaller one thats probably the asic, the smaller chip is not as high than the larger one i.e. when you have a single thermal pad to cover the lot as mine and I'm guessing most motherboards do the small chip is not getting covered by the pad at all i.e. its hanging high and dry with a gap between it and the pad. I had to cut a small portion of thin and squishy thermal pad to stick over the chip to meet the main pad on top. This dramatically reduced the temperatures to about 50-60c. The other two sensors are a much more reasonable 43c or thereabouts. Running a crystaldiskmark benchmark raised the temperature to about 75c which is under the operating temperature of 0-85c for this drive as opposed to well over 100c before (yikes) so I guess that'll have to do for now.I think Samsung quote up to 80c operating temp before it's classed as 'out of spec' but even so... 70c for an idle drive is well hot.
It shouldn't be idling more than about 40 or 50 tops, and most of that will be residual heat from cpu/gpu if its in close proximity.. So you'll never realistically see an idle temp of under 30c or so, for example
PCI-e 5.0 is a marketing gimmick for consumer PCs and adds literally nothing whilst costing way more and running hot.
If you are a database manager with a huge locally hosted set of database files then sure, PCI-e 5.0 makes absolute sense but otherwise, it won’t make any difference and most database systems are hosted on a dedicated server anyway.
PCI-e 5.0 is more useful for servers since it’s used to connect pci-e devices to the server using fewer pci-e lanes (you can get the same performance using half the pci-e lanes since the bandwidth is doubled).
For PC gaming and consumer applications, pci-e 4.0 is great and a drive like the 2tb SN850X is hard to beat for the money.
Yeah I agree. Gen 3 is plenty fast as is and most people won’t notice the difference.Doubt you'll notice the difference in games with gen 3 either
Yeah I 100% agree.I have a gen 3 WD Blue and gen 4 Kingston, don't notice differnce in games, only in crystalmark tests. Also have a 500GB 2.5" SSD used for Windows boot that is plenty fast enough.
