- 24 Mar 2018
- Brighton
Did you make those, I tried a while ago but failed badly to make them!Columbian buns
Looks in a perfect state of readiness to me. I been loving the Ben 'n' Jerry's Sweet Mango Memories with white icecream bitsNot the prettiest looking, but, homemade cherry and brandy ice cream.
I'd used some Xanthan in the mix.Looks in a perfect state of readiness to me. I been loving the Ben 'n' Jerry's Sweet Mango Memories with white icecream bits
Bought theseDid you make those, I tried a while ago but failed badly to make them!
I played about with this stuff for a while, you can get some good results but It's very specific use case and application. A little research is required.I'd used some Xanthan in the mix.
Bought these
These are a new area to me and with the intention of only using with the ice cream maker and so far the results are positive and to the point that I didn't really need to use the blade at the end.
I am tempted to play a little more with them though.
Would love an idiots guide recipe for something. Not had that much luck with my Creami although admittedly not tried much. Everything just comes out a bit too solid.
I followed the Strawberry ice cream recipe on the Ninja Test Kitchen and then added roughly a teaspoon of Xanthan Gum before freezing.
The gum stops the ice cream turning to a block of ice and means it can be eaten straight from the tub if wanted.
You may need to check out correct amounts of the gum to what-ever you are making.
I’ll tell you what, let’s meet half way!Back in stock.
