LG OLED 2024 thread - A4, B4, C4, G4
The soundbar is pretty good as a secondary sound system but glad I didn't get rid of by BK Mono sub and wharfedales for it
Anyone used this stand:
Sanus VTVS1-B2​
Installed, but the tv rests on the top part…should it rest on top and bottom?
I've used a couple of very similar ones - what do you mean, top part?
Pics will help.
Expert drawing:
The vertical bars are installed with two screws on each bar
Expert drawing:
Gotcha. This looks ok to me - just need to fully thread in those 2 long screws as they stop the bottom of the bracket being lifted away. Doesn't need to be done up tight, just enough that you can't remove the TV by tilting the bottom forward.
I’ve screwed them up, so assume the are up against the metal of the bracket (there are no holes) which I assume keeps it stable
Appreciate the help
Speaking of moving on, I just peeled the protective plastic off a C2 I brought back from work today. It's been here a month or so but I hadn't wall mounted it and got the height right.
You can see how much more reflective the protective coating is. It was driving us crazy watching during the daytime! The bare screen has much darker reflections and is slightly less dazzling/direct reflecting too.
