Annoying, i settled on a barbeque, ordered from one place only be to told it's out of stock 2 days later and offered a 5% discount if i bought a higher model at €700 more, then ordered it from another place only to be told that version isn't available but the enamel fronted version is (mine was stainless steel)
We've invited people round for a barbeque on the 16th and had hoped to have it before then. Now i need to work out whether i take the enamel version and have it in time or risk waiting for the stainless version. My preference is probably to stick with the stainless. It's very out of character for me, but if i'm spending that much it seems daft not to get the one i want
1600S Series - 5 Burner Built In BBQ
Cast iron cook tops for great heat distribution and consistent results Start cooking quickly and easily with our quartz start ignition system Seal in the flavour with our durable and powerful 4.2kW cast iron rail burners Double skin stainless steel roasting hood with temperature gauge for great...beefeaterbbqeurope.co.uk
i have been using the kamado all year, feeling guilty about not using my weber kettle more than a couple of times in 2025 after being monogamous with it for the last 5 years!
Been cheating a bit with corn on the cob by using ninja airfryer for it - quick, simple and predictable cooking
Yeah the Weber is awesome. I went Weber->Weber smokey mountain->Kamado->Offset.I really want a Kamado to complete my outdoor cooking kit. The Weber does produce some great results though!
I almost got a pizza oven too, I really want one, but trying to save ATM and they aren't cheap.
I just got an offset to chase the perfect smoke (Kamado is just too efficient), but I did everything before just fine on the Kamado and it was definitely easier. I still have the Kamado, was just one from Costco, definitely don't need an expensive branded one.Really like our Ooni 3 wood pellet oven. Super simple and won’t break the bank. I’m sure you can get fancier ones, but we’ve had great results with our occasional use.
Thanks for the tips on a smoker. I guess the dream would be a proper offset setup, but I think the Kamado would be slightly more versatile. Might be completely wrong though!
After watching a few more comparison videos, the Chef iQ one seems to consistently come in the top 2-3, particularly when price (and availability in the UK) is taken into consideration, the Meater seems a bit hit & miss, and I couldn't find any decent in depth reviews of the others I listed, so I went ahead and ordered it (ended up going for the 2 probe kit for £71).
Just done a quick test cook with it, just a couple of chicken breasts in the oven (hunters chicken), and I'm impressed - probably the most tender bit of chicken I've cooked in a long time; I tend to err on the side of caution so probably end up slightly overcooking a lot of the time.
The app is super easy to use, literally 5 taps to get started: set up cook > Pick the meat > pick the cut > pick the cooking method > start. Then just following the instructions.
Looking forward to some nice bits of lamb and beef on the BBQ over the weekend now![]()
This is a great summary if you want to try smoking:
