No, unfortunately not. He went on to quantify it by saying "so half the journey costs the same as my old diesel and the other half is basically free so it's costing me half as much"Maybe he's taking into account the fact that half the journey is done on cheap electricity charged at home (assuming leaving with 100%)?
You need the key in the car/your pocket too.you've got , legally I'd have thought, to use a button/interlock before driving off, otherwise your children could jump in and drive away just pressing the pedal
(the dreaded stop-start deals with the ICE car stop now, fortunately you can still drive the car with the door open though, for parking)
is there a summary for ‘spot on’.More high mileage EV reports, this one used to be a MK taxi type thing, seems like for the age/miles covered the mechanical and battery are spot on still.
It’s a bit like engaging sport mode on a diesel repmobile lol
It doesn’t change the handling…
It changes the power output, delivery and the way the 4x4 works making it 50/50 split rather than rear bios. Affects the handling quite a bit.
More importantly it makes all the dash and interior lights go red…. lol
Pretty sure it's the same as you simply stepping on the go pedal a bit harder in normal mode lol but the red lights sell it![]()
Think about it If you boot it in an EV it’s 50:50 ish anyway, both motors at max power and there’s nothing changing front to rear split other than reducing the output of one motor.It changes the power output, delivery and the way the 4x4 works making it 50/50 split rather than rear bios. Affects the handling quite a bit.
11% degradation over 220k miles. Saved you a blathering 12-minute 'man talks in car' video. However, I'm not certain the use case of a taxi is relevant to a standard owner.is there a summary for ‘spot on’.
. Thanks. Not sure why that couldn’t be posted with the video.11% degradation over 220k miles. Saved you a blathering 12-minute 'man talks in car' video. However, I'm not certain the use case of a taxi is relevant to a standard owner.
Not sure that’s really that great. 11 % is a fair loss and as you said it’s not parked doing nothing for long period like typical use. I did skim it. Any idea of how he charged it? All rapid or all 7kW
It's more than would be expected for sure, especially in a temperate climate like the UKI had some argue that 10% loss in 3.5 years and 41,000 miles was perfectly reasonable for a Cupra Born/ID.3. I totally disagree and at that age and mileage about 95% is average.
