Setting question on my TV/PC combo
18 Feb 2007
London
Wasn’t sure where to post this, anyway I have an LG CX oled and PC connected to it, rough specs 7800X3D, 4070ti super.
Should I enable AMD freesync premium on my tvs hdmi port?
Thanks
You do have maximum refresh setting, should be 120hz but sometimes it changes to 24hz.
On my C9 you go into dashboard to change it to PC input, so some settings are disabled and acts more like a monitor. Can still adjust some settings though
Do some freesync tests, I used to have a windmill test
I can’t find refresh setting, whats it under on your C9?
It’s only for that sim, it’s better, not sure if you play msfs24? It’s certainly more stable for me with max frame of 60.
It fluctuates too much unlocked and causes stutters.
You can run the TV's refresh rate at 120hz, it makes things smoother in general use so isn't just a benefit for games. Then you limit the games FPS to 60 and you shouldn't suffer any stutters, if you can't do this via MSFS itself you can do it via MSI Afterburner/Riva Tuner.
I’m yet to check, but I think it’s already set to 120hz in the settings, the only thing I change is in nvidia control panel I set max framerate to 60 just for msfs24 (not the global setting).
