I was too afraid to ask...@Gibbo Do you have a rough ETA and cost, please.![]()
It can go on the shelf next to my 4090 MatrixI was too afraid to ask...![]()
God only know what this will cost.
A 5090 shaped like a Penis, how appropriate for Asus![]()
Now I've got to watch it.
Nvidia selling cards to third parties that were flaunting sanctions and selling them to Chinese customers.What was it about?
Probably mentioned in previous pages:
This guide really helped me understand vf point undervolting:
Takes a good deal of testing for stability. Dialed in 0.900mv @ 2805MHz over several weeks and various stress tests and games, testing lots of different variables.
Thought it was stable for weeks with slightly lower voltage, then one game comes up and needs a little extra bump or two. Doesn't trigger power limits and is pretty cool running.
Recently found I could get +390 @ 0.935v @ 2917MHz.
The voltage increase per clock speed bump is definitely not linear, i.e. +405 works @ 2805MHz = 0.900v but +405 @ 2910MHz = 0.925v wasn’t stable. Very good starting point for working out the rest of your voltage curve going from low to high to try and get your personal chosen settings that meets temp and power preferences and game demands. I can keep the 2917MHz setting under 50c with my water cooled Palit card and mostly avoid hitting power limits.
I have just started testing the whole voltage curve, because I have pretty much tried every point at a clock speed and voltage that is almost on the money.
I have gotten to +390 @3007Mhz = 0.960v. This starts hitting power limits, but in many of the games I play it doesn't get massively hit and I can keep clocks at about 2900+ at slightly lower GPU usage and under certain game settings (Frame Gen, DLSS etc.) This only pushes the temps up a little bit and can function as my higher end profile for certain games. Still needs a bit of testing, but all pretty good info.
If it was shunt modded then I could keep all the clock speed I lose through early power limiting. Then I would go above 500w regularly though, which is not the goal.
All good fun anyway.
Just watched the vid. That is a lot simpler!Yes, that guide is GOLD! So much wrong info on undervolting out there on the internet it's unreal.
I've been undervolting my cards for years and thought I had it nailed down and got blasé about it. It seems the 50 series is slightly different though and I was actually doing my profile curves wrong for my new 5090FE.
You absolutely have to, like he shows, do a range first by holding SHIFT between 2 points - a low point (eg 0.815v so card still idles correctly) and the desired peak volt point (eg 0.895v) and then raise and flatten, which creates a different, correct 'shape' giving higher core boosts!
Before I was just dragging up the desired peak volt ONLY and then flattening the curve, which kept correct idle behaviour and volts etc, but created a much steeper shape and a slightly reduced performance/ lower boosting than it should.
For example, 3D Mark Steel Nomad I was only scoring ~137fps with my old 'incorrect' 0.895v profile whereas with the proper curve method and my 0.895v profile it's ~145fps! (Stock is ~140fps)
The vid above is a bit long and a deep dive. A good very short 3 min video I found shows the right way to do the curve also :
Yes, that's a good point. I set myself a limit of around 500W when I originally got the card.^ Nice one. You're watercooled no @0121danwilliams84 ?
With my (very new) 5090FE only air cooled and this whole melting cables debacle, I'm a tad worried so I'm really leaning into the undervolting game now.
For the stuff I'm playing at the moment, even intense VR stuff, I'm finding I really don't have to push the card at all though and it's just superb. I'm running most games with my very conservative 0.85v profile as the really demanding ones have framegen anyway, and you still actually need framegen if you want to hit above 100fps at max settings 4k, as I like to do.
Basically, you can run a game like Cyberpunk maxed out with the GPU at high volts and maxed out at 550watts+ and still 'only' get about 75fps and a risk of combustion. Or, you can run the GPU at a nice 0.85v undervolt curve, barely use more than 300watts, still get about 60fps anyway and then framegen that up to 120. Which actually reduces power draw even more on the GPU. I know which I prefer to do....
