- 28 Dec 2017
- Beds
Is that a PGM?
Is that a PGM?
Finally going to give guitar another shot.
Been looking at a Yamaha Pacifica, mainly the 120H or the 311H (leaning more towards the 311H).
Would also need a basic amp to get me started, any suggestions on where to start for a beginner? Might grab a Mustang micro to keep the family from going nuts too
What music do you like listening to/want to play?
The Yamaha is a decent guitar for a strat design. I started out on a strat too.
120H looks to be an HSS (hum bucker, single coil, single coil) tremolo, the 130 is a hum bucker P90 hard tail.
My old strat is a SSS with trem. The 120 trem makes staying in tune more difficult and if you set up the guitar then it makes it a little more fiddly. The bridge will move on bends of strings etc which can make it easier to play. The HSS will give you the classic strat sounds. The single coils will sound thinner etc than the humbucker normally but in the bridge position it helps even out the tone. It will be good all around tone guitar, yet in bridge the humbucker may steel some of the high thin 'strat' sound of a single coil in that position.
SSS and HSS Strats work well with distortion because it's characteristic thinner sound worked well with the old distortion pedals as the lack of bass prevented the distortion flubbing out.
The 130 offers a humbucker and P90. This combo will give you more of a deeper sound and will bring some fatter 'les Paul' vibes to the tone without the Gibson style guitar. It is likely to sound a little warmer and less 'strat'. It also offers a hard tail. The guitar has vibes of a telecaster/Les Paul love child.
SSS - think shadows, think police, and most bands in many genres..
HSS - think the above (slightly warmer bridge) extending into rock and metal.
HH (P90) - think led zeppelin, think oasis, think blues and jazz, guns and roses, etc..
I would say take the pickup thing with a pinch of salt. The main difference is warmth of tone but aftermarket pickups can make a massive difference to the tone. My current guitar is a custom build and has two aftermarket pickups and the difference in clarity is noticeable compared to my little strat stock pickups. There's always something you can improve but in the end this is your learning guitar.
I believe the neck is thicker in the 130 from what people are saying - the neck makes/breaks a guitar in the hand. If you're learning, it's not really going to make too much of a difference. Once you get into the more complex chords and you develop what is comfortable then look at that.. you can change necks too with aftermarket ones or simply another guitar
The mustang offers some different tones in a small package, but it's also a mini-amp for headphones that at a later date you can add pedals in front of, even adding modelling or analogue pedals without needing an amp itself. As a kid I used to use the headphone out of a Marshal Lead 12 for the majority of the playing which is basically do the same, only difference is when the family is out the amp could be played naturally. So the mustang is a good option - only thing is power, it's rechargeable, so remembering to have it charged is a thing and there will be a time when the battery dies.
As long as the amp plays clean, you can apply any effect or change speaker and offers a 'music in' mixer so you can play along when wearing headphones.
Note on pedals - the mini pedals are too small to put a battery in. This means you need to have a power adaptor. This is why I have some pedals in the normal size (my tuner being one).
What I would suggest is a tuner - a plug in one works better with noise around, and you will find you enjoy an in tune guitar more. Popular tuners are polytune, korg, boss, and up the scale Peterson etc. A chromatic tuner (one that shows you how far out of tune you are and which note it's thinking it's detecting) is very usefully. Strobe tuners are a step up and more accurate. A poly tuner allows you to 'see' the tune of all the strings but trades off the accuracy of the display to "you're in tune" or "your flat/sharp" but not by how much.
I would probably advise you spend a little on a tuner that works for you as you will be using it a lot. I started with a tuning fork for E, then got a korg tuner that was ok for acoustic and electric but I now have a Peterson stompHD due to it being extremely accurate, readable at a distance and copes with any tuning (including working for 7 strings). It's the most important pedal.
Naturally a clip on will work so you don't have to keep unplugging the mustang mini and it's easier for travel/space.
Also it's worth getting an extra set of strings, and extra plectrums.
What case will you have?
I have a simple case, it's protected the strat for years (it's a 1988 model), hanging a strat is also an option if you want easy access but light fade and dings happen. The easier it is to pick up, the easier it is to start playing which is important when learning.
Thanks yeah I've got some good answers over there but a bit of mixed messaging regarding what to expect out of each sound wise so that threw a spanner inNeither of those Pacifica models has any Strat style single coil pickups. That said, I've bumped into your post on Reddit and I think it's been well answered
Better quality tuners and nut is a good shout. Pacificas have always had brilliant build quality and QC so things like fretwork and materials/finish should be consistent between the two really. Upgrading some of the hardware is a meaningful inprovement.
What an informative response, thanks a lot!
I think I'm leaning into country/rock. Big fan of say Chris Stapleton and sounds similar to his which imo is a blend or rock/blues at times so I'm wondering if the 311H may be the better bet for me in that regard based on the above?
Not into anything heavy/metal etc
I did same, they all look like HH. Both guitars are hard tail as well so maybe you got some shopping results that weren't quite accurate?I googled and it seemed the 120H was an HSS?
This is true TBF, I dislike locking tuners as is extra faff to me. But the idea of an upgrade is nice. It depends what tuners are on the 120H I guess!Not sure you really need locking tuners to be honest, but what is really nice are 18:1 tuners.
Thanks. I did consider a telecaster for a while. I kind of feel I should go for the most versatile option as a pure beginner.
I'm wondering if I go for the "nearly new" 120h, I'd make a saving of £70 over the new 311h which I could put on a pre-owned amp or something.
Just don't want to make the wrong choice
While I have you, amp wise id just want something small to practice on for now. Are Black Star 10 any good? Got a few for sale near me for like £50
The obvious question- budget?
The reason I asked the what music is it helps narrow down the choice.
Chris Stapleton = Fender Jag + P90s into a Fender Princeton. Naturally there's modifications and customisations but they form the basis of the tone. It will also do rock and others but the Princeton is a clean sounding amp, the P90s give a neutral/warm sound.
So we could do: Pacifica 310 -> Mustang Mini -> headphones and that would work. The mini has settings to 'model' the amp so it will sound like Including various Fender amps, and others like the Vox etc, with clean through to heavy distortion, it also has reverb etc. Page 4: https://www.fmicassets.com/Damroot/Original/10001/OM_2311300000_Mustang_Micro_US.pdf Note that the Plus adds more amps including the Princeton ... for a few squids more..
Another 'modelling' device is the GP5, it uses your phone to mod the parameters so it may last a few years before the software disappears. It's got good reviews and the output will do headphone and line.
Loading…
www.andertons.co.ukMore flexible than the Mustang mini (will plug into a larger amp as well as headphones), but it's mini format will require a 9V power brick (the standard is centre NEGATIVE and not positive for pedals so be warned). It is preloaded with hundreds of models but also can import new NAM files. Note you can select the model of amp and the speaker cab, mix vice versa. It has Fenders (Page30: https://res.valeton.net/Uploads/wp/download/1748936007255.GP-5_Online Manual_EN_Firmware V1.0.3.pdf) but not specifically the Princeton. It also has an inbuilt tuner. You'd need a cable to get from the guitar to the pedal and long enough to get back on the headphones.GP-5 – valeton
www.valeton.net
Later you can rock out when you get an amp by just playing this through it, unlike the Mustang.
The Black Star 10 is a modelling amp. It's also discontinued so its compatibility with their Architect software for downloading new patches etc is on a whim and one software update it may stop working. It does have an inbuilt tuner mode (hold reverb) but its patch information is simply "clean', "crunch" etc rather than specific amps sound. No idea how well they will work for getting your intended sound. Solid state 10W is reasonably loud for bedroom use. It has other features like reverb etc but, again, they're a little wishy washy about the specifics. Try and Dial..
Lastly if the BS10 dies then it's not really serviceable from all accounts. People attempting to shift them on may be for a reason.
Boss Katana is decent, but larger/expense...
Pulled the trigger on the 311h![]()
So now I'll either get a Mustang micro or a small amp now, and get the other later.
My thinking with the micro was I could just practice without annoying everyone
But then I guess amps have headphone jacks too so maybe a small pre-owned amp would be a better fit to start. Best of both worlds until I find my feet/give up
Any advice on virtual amp sim software to play about with? I have Logic on my mac which is fine to record (used for other stuff in the past so not used for guitar specifically) but it just feels a bit of a slow process to swap settings, pedalboards etc for experimentation. I have a Scarlett audio interface and ideally after something that works on MacOS
