Any easy way to disable/switch between hard drives?
5 Jun 2017
UK
Is there an easy way to quickly disable/switch hard drives without physically disconnecting them?
It's just that I've got a lot of drives I don't use as much - small older drives, backups, archived stuff etc. I don't need these hooked up all the time, nor would there be enough cables to do that anyway. Plus I've also been thinking about running two different operating systems from the same machine, so I'd need some way to switch before booting.
Surprised there doesn't seem to be any switcher cables out there. How do most people deal with multiple hard drives? Is it only me who keeps all his older drives for extra space/backups?
I do this by enabling/disabling required sata drives in the bios (Asus B650E-F). Don't think NVME drives can be controlled this way (outside of server/workstation class boards).
But for sata drives it's a breeze. Enter bios, enable Sata drive 1 (Windows), disable sata drive 2 (Linux Mint) and vice versa. Neither systems can see the disabled drive so it's a robust enough mechanism.
Personally I would just consolidate all the old small drives into a single large external drive to save having loads of them around and plug it in when you need it.
Multibooting isn’t a big deal, no need for multiple drives can all be done from partitions on the same drive if you want and then choosing which OS to load after post. There are various tools to set that up, but it’s been many years since it did it…
Thanks for the great replies guys! :-)
What type of drive SATA or nvme?
SATA (all HDDs except for my OS drive which is SSD).
Interesting, I thought the boot drive always had to be the primary partition? Nevertheless, I don't want multiple operating systems to be accessible at once in case I get a virus on one, it would infect both. My whole reason for wanting two operating systems is security. One will be used only for web browsing, the other will be offline, used for everything else.
Great idea, thanks! (Though I would worry that a virus could somehow mount it from Windows. Not sure if this is possible?)
I've decided I will:
1) Try to ditch all the old smaller drives, to keep my drives down to just 6, so they can all be physically connected.
2) Then I'll use the BIOS to enable/disable the ones I want.
Thanks!
Can always combine all the small drives
Windows storage spaces is great for doing this
Doesn't matter if drives are different sizes,or if sata hdd,sata ssd,m2 etc
Can't say have ever heard of a virus
That could mount a drive that's disabled in the bios
But as a precaution my macrium image back ups
They have macrium protect turned on
It stops tampering,deleting etc of the image files
Got 9 drives not including externals lol
And multiple Windows installs on different drives
Not a fan of installing more than one windows
On a single drive using partitions
If the drive fails you lose all the windows installations
