BehaveOr... EA pulls Steam purchases and makes it an EA App exclusive then raises the price?
You should have done the user.cfg tweaks with the core count and threads, it made a massive difference.Yes the #1 issue by a mile. CPU at 100%, have to severely limit FPS to tame it, GPU barely used.
The retarded 120 degree FOV makes it look worse, like what kind of bug eyed people use 120 FOV, damn..
That also seemed about 50/50 whether it helped people or not, and ofc the user shouldn't have to do that. Didn't see anyone with e cores saying it helped. Most people had 8 core 16 thread CPUs.You should have done the user.cfg tweaks with the core count and threads, it made a massive difference.
I really like that they've done this for the beta, adds an extra little bit extra for those who want to keep an eye on how they're playing.You can now check out your stats.
Battlefield™ 6 SEASON 1 RECAP STATS Player Stats – Electronic Arts
See your Player Stats during the Battlefield™ 6 SEASON 1 RECAP STATSwww.ea.com
It was discussed a little a couple of pages back, some data miners have figured out that the likes of Mirak Valley will be quite significant in size (comparible to some of the largest BF maps), aswell as firestorm which will be the two biggest launch maps. All out size means nothing though. Take Liberation Peak for example. medium sized map but due to map design ended up effectively with two bowls with three choke points to channel people through. This lead to very linear play and little scope for out of the box moves.Is there any more info on new maps and their sizes?
Thats the **** we want to see, certified BF moment!
YesIs this actually any good? I’ve avoided youtube videos etc.
