- 6 Sep 2016
Does anyone know which 9070XT models are best to go for to avoid coil whine? I've been using Sapphire Pulse for a little while and it's not usually a problem in games that have Anti-Lag 2 or games where I roughly know what to cap FPS at so I don't go above 95(ish)% GPU util - but for other games the coil whine can be the loudest noise coming from my case.
Or is it just a bit of a lottery and it can differ from one card of the same model to the next?
My sapphire pure has pure whine at 180+hz/180fps+, although I might just test it again by disabling freesync, target frame lock as apparently coil whine can disappear as a GPU "settles in"
