Can anyone throw an eye over my new gaming PC build list please?
I'd say so, especially if you reduce costs elsewhere, you'd not be spending any more money after all with some shuffling.
I've built many rigs over the years, an M-ATX case like that isn't any more difficult to build into than a larger one to be honest. The only thing that makes things a bit more difficult would be if you've a non-modular PSU, or a PSU with exceedingly long cables. The Lian LI PSU you selected is actually designed for use in the sort of case I linked, that's why it has the funny looking shelf type thing for the connectors.
If you'd prefer a larger case and like the look, there are some well priced ones out there with similar aesthetics.
Revised build with a larger case:
My basket at OcUK:
Total: £1,434.86 (includes delivery: £11.98)​
Still cheaper than your initial post and includes the X3D.
Thanks for help btw, should I just go 7800x3d? How does build below look, any problems?
Looks good to me, I'd check some 7600X3D reviews where it's put up against the 7800X3D and decide from there, personally I'd not spend another £80-100 for the 7800X3D but if you can fit it into your budget it's not a bad purchase.
More ordering 7800x3D because its in stock as I'm off next week and hopefully building then.
Fair enough, I've seen them in stock elsewhere but obviously I can't mention where due to competitor rules.
It's a solid selection of components and you're not paying silly money for anything on the list, Id be happy with that. Not a case I'd go for but if it's to your personal taste there's nothing wrong with it, I've heard good things about Montech cases and a quick gander at the specifications shows everything should fit just fine.
I'm PC building novice smaller cases just make me nervous, for absolutely zero reasons. They do look amazing though.
Thank you for looking at specs on Montech
I know it's £50 more, but with he 9800x3d dropping below £400 now, i'd get that rather than the 7800x3d for £350. if you're thinking maybe upgrading gpu down the line, i'd prob plumb for the 850W psu also as a min..gives you a bit of room if you get a more powerful gpu...otherwise a gpu upgrade may involve a new psu also, and the psu has a 8yrs warranty i think, so s/b good for your next upgrade.
regarding the case...the montech design is a bit old with the leading edge having a metal support down it rather than just glass to glass...I've got a 011d evo which is similar, and the bar can get really distracting seeing as it's a goldfish bowl design (spoils the aesthetic a little...I'd maybe look at a few others such as the phanteks xt view, antecC3/CX700, the lian li V100, corsair 3500x, as alternatives
