~ 850W PSU without breaking the bank?
29 Jan 2022
UK
I'm running the below spec on a 650W NZXT C series PSU (A tier, based on Seasonic Focus Gold) and realise I'm on the edge of what PSU I should really be using. I don't really have a budget so my options are:
1) Continue to run as-is with a power limit reduction on the 9070XT
2) Buy a new PSU
I don't really want to have to spend any money but it's probably sensible, there are a few ~850W around the £100 mark and I don't need anything fancy apart from modular.
I'm tempted by BGrade PSUs as they'd be cheap but 10yr warranties are very tempting.
Any suggestions?
7950X3D
Arctic Freezer III 240 AiO
XFX Swift 9070XT (power limit minus 7%)
Asrock B650 PG Lightning
32GB 6000 CL 28
PCIE Wifi 6 card
The 9070 series respond well to undervolting, I'd do that and see how you get on. You shouldn't see any performance loss. I know a few people running them on quality 650w units without issue. Worst case you get shutdowns, with a high end supply you've plenty of built in protections, nothing should get damaged. Best case it works fine and you save yourself a £100.
I'm at -50mv and -7/9% power, I think it's probably ok but as mentioned the sensible thing is to get a new PSU :/
Can get a Gigabyte UD850GM for £80 (5 year warranty) or a Corsair RM850e for £104 (7 year warranty). Gigabyte should have fixed their fire problem but it might be worth going with the Corsair for peace of mind.
How much power are you actually using when gaming (whole system)?
Do you game much?
GPU hits up to 300W at full tilt (if I uncap fps). CPU ~ 80-100W (Playing Ghost Recon BP).
Spikes are probably the biggest issue, I've had a couple of blackout reboots before I dropped the power which I attributed to spikes and haven't had them since so I'm making an educated guess that I'm on the edge.
Yes I game a fair bit.
You could be brave like me and get a Montech Century II 850W PCIE 5.1 80+ GOLD Fully Modular ATX3.1 Power Supply :D Can find it for £80 new. I got the 1050W version for £100 a couple of days ago.
Early days yet, but I'm encouraged by how it's resolved the coil whine issues I thought were due to my GPU.
