*****Official BBQ Thread - Suns out, Buns out!*****
What method do you lot use for cooking corn on the cob, normally I put it directly on the grate, be it pre cut corn or corn in the husks. Is wrapping the corn in foil and adding a layer of butter perhaps a good idea?
If anyone uses foil what's your method please?
If it's in the husk I'll usually steam it first then grill, then just add seasoning/butter at the table.
If it's not then wrap in foil with some butter/seasonings of choice then on a low grill until cooked then finish without the foil to give it a bit of char.
Great thanks for the tips.
Boil for about 10 mins, onto foil, knob (matron!) of butter, wrap and into the BBQ
I usually wrap the corn in foil with some butter, salt and pepper and then stick it in the bottom of the Weber BBQ in the area without coals. No pre-cooking required. It's pretty forgiving and as long as you're not doing a long cook, will work well with 45 mins.
The other alternative is in the husk. Get rid of the silk, soak the corn before cooking to wet the husk. Stick some butter under the husk and stick in on the BBQ. I would put this on the top of the grill rather than under it in my setup. It's more resilient to direct heat and I think you should be able to put it directly on the coals if you could give it some attention.
So the outcome of the BBQ bacon fest with the different woods, it seemed Hickory was really popular. The Mrs and I both agreed - it's got a cleaner smoke profile. One of the guys has decided to get a small smoker as a birthday present.
So with the same cured but uncooked/smoked bacon from Sainsbury's:
* Webber Apple chunks - has the normal almost malty fruit tasting smoke
* Neapolitan Cherry chunks - has the slightly heavier malty fruit taste smoke
* Webber Beech chips with some soaking - I did these a little longer, as a result they had a heavier smoke, not fruity but still has a tang in the smoke.
* US Oak (sealed food grade US oak for maturing wine) 1cm cubes soaked - has a smell of burning oak, with a mellow savoury smoke taste that's more subtle than hickory
* Webber Hickory chips with some soaking - has a clean and very present smoke taste, that doesn't have anything else messing with the taste of the meat.
I have small foil sealed bags of the oak I used for beer making. They're food grade so there's no problems. I'd imported these in about 2008 as the US Oak taste is mellower than the harsher French oak used in wine and so in beer the mellowness works better. It also presents an open mellow fire pit smoky taste.
It's interesting that there's a marked difference in the smoking between the sealed bags of the webber and the Neapolitan in a box. The boxed wood was dryer and seemed to loose some of the final impact with the food.
The idea of doing bacon is people can pick and try different woods, and complement the BBQ food when they're not so used to smoked foods.
recently for corn on the cob i have been cheating by using the airfryer - into a freezer bag with a little oil, add in some rub, coat well and then 180 degrees for 8-10 mins. it saves a bit of hassle from cooking on the kamado. drizzle some hot honey sauce over them after cooking - lovely!
Been contemplating upgrading my Aldi Kamado for a while now, and going on a Smokin' Elk cooking class back in July affirmed that, having been cooking on it pretty much every day since, had been keeping an eye on the deals and this came up for £1300 after discounts, so jumped at the option!
Now to get a few accessories, charcoal basket, Joetisserie, sear Griddle and soapstone initially.
Went to the butcher to get a Picanha for this weekend. I’ve ended up with a 2.5kg lump.
From all guides to cook it seem to suggest around 1.5kg being the sweet spot.
Anyone have any advice. I’d prefer to not cut it in half but that is an option and would allow different cooking levels.
It’s pretty much my first time doing anything big on a bbq. Usually I only cook for the family but have around 12 people coming round to celebrate getting carried away with a 5 burner gas bbq.
(Note I’m also a beginner with gas. Last weekend was the first use of it but used the rotisserie for a chicken which was amazing)
finally found some good char siu rub and marinated a porkfillet in it for a day before cooking on the kamado - came out lovely with a dark red ring just like from the local Chinese :)
Cooked it to 65 degrees internal. definitely something i will try again!
Oxtail stew for days! Smoked, flame grilled and sous vide.
Sadly I didn't take a picture of the end product as I was to busy eating it! Rest in the chest freezer.
