These "all in one" retro console things you see on faceache etc?
Caporegime
25 Nov 2004
On the road....
I'm considering reliving my gaming youth and quite fancy one of these all in one consoles you see frequently advertised on Facebook et al, what concerns me though is the legitimacy of such adverts never mind devices...
Can anyone point me in the direction of a legitimate product that will fit my needs?
Looking particularly to relive my PlayStation (original) days etc, a lot of the products I see advertised seem too true to be good...
Yeah, as above. I got one from Ali for $56 delivered, the same one via instagram was $200. I got the R36s with 128mb memory card.
Well worth the money, all the arcade games I played as a kid are on there, in all their flawed glory. Played a lot of Double Dragon and Pit Fighter. They are pretty much what they look like in the adverts. Can't find a way to use Bluetooth headphones with it is my only complaint.
The ones that you see are loaded with unlicensed roms. If you're happy to break copyright law then you might as well just build a similar set up with an old PC or raspberry pi.
I've already got a fair few emulators on my PC for various devices such as 80's & 90's home computers and consoles, it's more the convenience of an all in one device I could plug into my TV and use like a console of old.
Fair enough. Just be careful with these "plug and play" ones, especially when it comes to the CD based games the ROM sets tend to me quite small, or some unusual collections.
Playstation can be emulated with relatively low power so you might have a device already capable of it, the problem may be storing all the PSX backups.
Can't help but think it all sounds great, playing all the old games again but then another part of me thinks I'll get bored and the novelty will wear off after 10 minutes!
Was about 30 for me. :D
I played mostly the old arcade games from my childhood. Amazing when you realise they are all basically the same just with different coloured sprites.
It does. I bought one and fired up a few games that I loved as a kid, poked around for a few minutes in each one then got bored and gave the device to my brother (who did the same)
Well, you've answered my question!
With this in mind, I fired up a few emulators on my PC yesterday while I had a free afternoon, Original PlayStation, PS2 and some NAME(?) arcade machines.
After about an hour, I found myself disappearing down the usual YouTube rabbit hole! :o
So much for that idea!
Thanks for the input guys. :)
if you want to pony up some cash i think the steam deck will give the best experience, but i hear good things about some of the older retro ones in the retro section :)
I bought an ANBERNIC RG35XX H a couple of days ago for 50 quid from the official site. Got a 128 GB Sandisk all prepped with a fresh install of Garlic and NDS capability and just found out it takes 3-4 weeks to come from China. Was really looking forward to testing it out but will have to be patient.
Imo make a decision about where your cut-off point is for games you want to play. Prices rise a lot at the upper end, but it's necessary if you're set on playing PS2 for example.
If you're happy with PS1 and below, this opens up a lot of the cheaper (up to £50) devices. Saturn can be a pain, as can N64 due to controller/processing power requirements.
I bought a TrimUI Brick primarily for old handheld games/RPGs (GBA and below, PS1 and below) and it's been fantastic.
Definitely do not buy off social media adverts, as they will all be middlemen/drop-shippers).
They are - they're dodgy Chinese products running pirated ROMs... piracy is literally the point of those things.
If you want to relive your PlayStation days then you could buy a Playstation (and a CRT).... but what many of us weren't fully aware of back then was that they crippled the games in the UK market - PAL vs NSTC - our games ran slower (50Hz) and had letterboxing/were squashed - worst case outputting a 576i image in 4:3 but containing a squashed 480i image within it - so you get 17% of the screen taken up with black space where in the US of Japan you'd have the non-squashed 480i image displayed in the proper 4:3 ratio - you could see this in the original Gran Turismo game. (Though unlike the SNES/MegaDrive era they did tend to adjust the speed of play to 50Hz).
Then in some later games they'd try to reduce the squashing effect - Gran Turismo 2 IIRC was rendered at like 512i or something, so you'd get a slightly higher res but also slightly squashed still game with less noticeable letterboxing and adjusted to run at the right speed (but not as smoothly as 60Hz).
This got better with the PS2 - in that case you can output some games at PAL60(480i) - so the proper 60Hz speed and no letterboxing and better (PAL) colours.
So what could you do today? you could get a PS2 second hand and play both PS2 and PS1 games if you like - get an RGB lead or SCART at least... (and/or perhaps look into CRT TVs).
Or you can get the mini-console - the PS One comes with a bunch of games, I've not played it but it should solve the old letterboxing issue as (though the UK version contains a mix of old PAL and NSTC ROMs they're having to scale the image regardless up to fit a 720p output so the image should take up all the vertical space AFAIK - should in theory look good on a 4k TV set as that's just a straight integer upscale but in practice they don't necessarily do that behind the scenes - perhaps someone who owns one can comment). Obvs that does still mean I think there are some games running at 50Hz still but given the image issue is solved and the game speed was adjusted for 50Hz by that era then the only niggle there is some smoothness issue.
tl;dr
If you specifically want to play the original playstation games then I'd probably just get the PS One mini console - legit product and comes with a bunch of games + no faff to connect to modern TV.
